Page 39 of 40 FirstFirst ... 2937383940 LastLast
Results 381 to 390 of 393
Thread: Tips for breaking in a brand new engine?
  1. #381
    Mar 2008
    Sunshine Coast
    The engine is already run in from factory (have a chat to Guy). However, other compnents need time and often forgotten about (tyres, gearbox, suspension, steering)
    The general consensus has been to not excessively labour the engine or drivetrain, don't maintain constant revs, don't redline the engine, especially when cold. Common sense.
    Best advice is to follow the user manual, it is there for a reason. If something goes wrong, you have followed the manufacturers advice
    My R is almost due for its 30,000 km service, doesn't burn oil, runs "like a dream" and I followed the manual (plus common sense) on the run-in procedure.
  2. #382
    Jul 2012
    Gold Coast, Qld
    I don't understand these "doesn't use a drop of oil" statements. I've heard it before, not just from Lucas. These engines are DESIGNED to use oil. Oil gets burned. The service intervals are what they are because of the tight tolerances of the engine. Come oil change time, you should have about a quarter left of oil, just before needing a top-up. If you run your engine particularly hard, you might need to top-up BEFORE your scheduled oil change. My car has been run-in hard from day 1. Tuned at 1000km. At 3000km, the oil level read 3/4 full. It's now at 4000km with slightly less oil. I have no issues with an engine losing/using/burning oil. What does one think catch cans and PCV's are for?
    Click or tap --> MY13 CW Golf R | Manual | ACC (deleted) | 19" Black Talladegas (sold) | Satnav-Dynaudio
    APR Stage 2+ w/RFD | Autotech HPFP | IE CAI + BSH Heat Shield | NPC Clutch + SMF | HPX 3" TBE | CTS FMIC | VWR Short Shifter | Comp Haldex | Uprated Engine Mounts | MCA Red Suspension | HP Superpro LCA/ALK/Ball Joints | Superpro Rear Bushes | AP Racing BBK | P3 Gauge | 16% tint
    Track wheels: 18x8 ET45 Enkei Racing PF01 | Tyres: 245/40R18 Yokohama Advan A050 Soft | Street: 245/35R19 Michelin Pilot Sport 4 S
  3. #383
    Mar 2008
    Sunshine Coast
    Quote Originally Posted by Machine View Post
    Mine doesn't. Actually, the GTI we owned rarely used oil either, all the way through to 80,000 km.
    My two cars must have been poorly designed outside VW spec
  4. #384
    Dec 2008
    Sydney/Canberra
    Yeah, they are designed to burn a bit of oil, but if you're doing your best to minimise it, you're not going to damage the engine in anyway. Unless you get a bit carried away, of course...
    When we picked up our new car (Not worth mentioning Japanese small sedan), within two weeks, we'd done just over 2,000klms including a run down MacQuarie Pass to Wollongong and back, and a 700klm trip to Tamworth via the Putty Road.
    While the manufacturer may have a different take on all of this, the driving in those first few weeks has certainly had a positive effect on fuel consumption, performance, and oil consumption. It'll get 750klms to a tank on a good run, whereas similar examples struggle to get anywhere near 650, it revs cleanly into the red zone making the most of it's MIVEC sorcery (Whoops, there's a clue), and still reads right on the full mark on the dipstick prior to servicing. Others I've driven, don't seem to feel as willing.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  5. #385
    Jul 2012
    Gold Coast, Qld
    Quote Originally Posted by Candyman View Post
    Must've. Or else you drive like a nana
  6. #386
    Mar 2008
    Sunshine Coast
    I rarely exceed the speed limit but I don't waste time getting to it
    Should have little to no impact on oil consumption in reality
    Most of my commute is a mix of 50-90 kph driving, 100-150 km/day
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
  7. #387
    Jul 2012
    Gold Coast, Qld
    I drive a similar daily distance but twice as fast. I do believe that these factors play a role in oil consumption.
  8. #388
    Erskineville, NSW
    My engine was run in "under load". It use about 100ml every 15,000km (you can barely discern the level drop on the dipstick). I actually thought I was getting fuel dilution but my commute is too long & I had an oil test done & hydrocarbons were minimal
    According to the MFD, my average speed(2) is 45kmh. My daily 90km commute sees speeds up to 110ish. My kids found out how to read the peak speed on my GPS & kacked themselves laughing at the look on my wife's face when she found out what I occasionally give the car a squirt to
  9. #389
    Speaking of oil consumption......
    A girl i work with has a current shape Audi A4 with the 2.0TSI engine (same engine as current Golf GTI and Skoda Octy RS etc). Anyway i asked her yesterday why she had a different car as i had seen her driving a silver A4 instead of her actual car, which is a black A4.
    She told me that it had been in to Audi to have the pistons replaced because she was using 1L (approx) of oil every 1,000km's. She is quite the "princess" so you can imagine that she isnt too happy having to pop the bonnet and check the oil on her car all the time.
    Anyway, she had the pistons replaced, was told that this should be the end of the oil consumption issues. She went away last weekend up the coast and ding, the oil light came on again. She had to buy a container of oil while on her weekend away to top the car up.
    So the car is back in at Audi again now being assesed. They have said that her timing is out aswell which probably explains the "roughness" that she was explaining to me. (roughness is in addition to the oil consumption issues).
    My brother works at this dealership so ill try and suss out what the go is.
  10. #390
    Mar 2008
    Sunshine Coast
    Holy crap Lucas, that sounds pretty scary
    Be interested to hear the outcome !
