Results 1 to 10 of 393
Thread: Tips for breaking in a brand new engine?
    Mar 2008
    Sunshine Coast
    Quote Originally Posted by easeup View Post
    When it comes down to it.. as much as i love this car.. i'm not really planning to keep it too far beyond the new-car warranty. So i'm going to enjoy it from day one. Is that unfair to the second owner? Probably, but you can't buy new things always thinking about their next life. The next owner will also gain the benefit of my meticulously clean interior, careful parking habits, and scratch-free paint
    Manifesto of a GTI with nearly 4000 km's comprising of plenty-o-redline...
    Will very likely be a far better engine than one that has been babied.
    Opinion varies but a number of "experts" suggest the running in is done in the first few hundred kms in terms of rings bedding in etc
    After that, it is case of not abusing the vehicle, good maintenance and common sense.
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
    Sep 2011
    Blackburn, VIC 3130
    Would tracking a brand new Golf R be a good idea to break it in? Not going to push it to the max but at least there are chances to drive it fast and on all gears.
    Quote Originally Posted by cavinsoo View Post
    No worries at all.
    I've taken brand new motorbikes from the shop straight to the track before, it's a great place to break in new engines. Just make sure to check your oil regularly.
    I prefer to run all my engines in a bit harder than your average Joe (whilst still showing mechanical sympathy)...
    MKV Golf 2.0 TDI DSG Sportline. Just nice.
    melbourne
    Quote Originally Posted by stickshift3000 View Post
    damn straight. spank that isht (once warm, of course).
    funnily enough, "strategic, gentle running in" hasnt seemed to work for any of the clio RS boys, who all seem to come back from dyno days feeling a little disappointed (as far as i've read, no one is making advertised stock power of 200, many only coming up to between 180 and 192/3 at most).
    the evo magazine long termer, on the other hand, which had been thrashed like a rental car..... dyno'd 6hp MORE than advertised stock (200). no mechanical issues either, iirc.
    so yeah. thrash it regularly.
    p.s. this isnt a dyno discussion - the stuff i've read is mainly uk based, so there is no "the high numbers were posted in dense winter air, whereas the low numbers were posted in the middle of the simpson desert" factor.
    Erskineville, NSW
    Start at 5/10ths & work upwards. You should feel it as it gets tight. Keep in mind you are also breaking in gearbox, wheel bearings, brakes, etc
    Sep 2011
    Blackburn, VIC 3130
    Thanks, Brad. But what do you mean by "Start at 5/10ths"?
    Erskineville, NSW
    Like 50% throttle or if a corner can be done at 100kmh then early medium brake & tip in at about 50-60kmh.
    The best way I can describe it is imagine you have your Dad's car & he is in the passenger seat & you're trying to prove to him that it's safe to use his car at a track day.
    Sep 2011
    Blackburn, VIC 3130
    Right. Just take it easy. Got it. Thank you very much~
    Jun 2011
    Perth
    Quote Originally Posted by Candyman View Post
    And when it comes down to it, an owner must assume that what the DSG allows is OK for the engine. I am surprised that the DSG in S allows the revs to come to 7500rpm... but it does. Which, once every couple of weeks, helps me surprise a HSV. But it's only every couple of weeks.. normally i'm just late, and late only means 6000rpm
    MY11.5 5dr GTI // Carbon Steel / DSG / Detroits / RNS510 / Bluetooth / Euros
    Feb 2010
    Oil usage at 27,500km?
    The Mark 6 Golf GTI is not far off clocking 27,500km. Only one service since new - 15,000km scheduled first service only. In others words, that's 12,500km since last service.
    Oil usage - None.
    That is despite a few short trips in the colder winter months. Very happy about this. Who said that the EA888 motor drinks like a siv?
    Cheers.
    WJ
