Page 13 of 40 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 393
Thread: Tips for breaking in a brand new engine?
  1. #121
    Feb 2009
    Sydney, Australia
    It is spot on.
    It takes longer to warm up engine while idling on the spot and longer engine idles, more unburned fuel enters the sump and degrades the oil. I let the engine idle for 20-30s and then drive gently until the engine is at operating temperature.
    Thanks for the info Transporter. So that explains why all car manufacturers require their cars to be serviced in shorter intervals if the car is subject to lots of idling, because the oil goes to crap quicker!
    Yeah, I turn my car on, and as soon as the idle has dropped from ~1000rpm to ~700rpm, I gently drive away. As far as I'm concerned, you don't need any light - that's how VW is letting you know the car is ready to drive away
  2. #122
    Quote Originally Posted by coreying View Post
    I get in the car, start the engine, tune the radio, put seatbelt on and drive off. Engine warms up much quicker when driven.
  3. #123
    Feb 2009
    I noticed on the MK6 the oil temp doesn't display a figure on the MFD for a while (~5 minutes). What is a reasonable operating oil temp when you can start caining it? 70-80 deg?
  4. #124
    Apr 2010
    Quote Originally Posted by G-rig View Post
    Im not sure if its a time thing or if it just doesnt read below 50c. I notice that it always starts to display at 50c,51c,52c etc.
  5. #125
    Feb 2010
    Not much point in having the Golf sitting stationary idling. They’re built to be driven straight away. Driving off ASAP allows oil pressure to build up & a bit of friction also generates heat. Best not to rev it much more than 2500rpm for GTI, not until the coolant & oil come up to temps. I leave the DSG in Auto until temps warm up. We’re not taxi drivers that keep their cab motor warm 24/7 and achieve up to 500,000km from a motor.
    The driver’s manual states that after working the motor hard, whether it be high revs or excessive load, the driver should idle the motor for 2 minutes to allow temps to normalise prior to switching off the motor. I like to coast in Auto and for this time of year, try to have engine oil temp drop to 95 degrees Celsius prior to shut down.
    The MKV/MKVI GTI motor does automatically run the pump & fans after shut down to cool the motor as no air is circulating around the engine bay. The owner’s manual indicates this.
    In the 1980’s, the Nissan Turbo Group A and earlier Nissan Skyline Turbo race cars would have the turbo give up after the first pit stop. In racing, the motor has to be shut off for the pit stop, and in those 30 seconds, the engine bay temp sky rocket without any air-cooling, causing damage.
    The owner’s manual also states that when put in neutral, the DSG gearbox oil pump switches off. Never coast the DSG GTI down a hill in neutral – the gearbox will seize from lack of oil.
    The DSG is designed to be a sealed unit with wet clutches that should last the life of the motor. Wet clutches are designed to slip.
    The run in period for the MK6 GTI is 15,000km. This is the phase where mineral oil has to be used. Dealer gave me a warning in case I was going to do a DIY oil change between services.
    I found that once you change to synthetic oil, the GTI uses a bit more oil. The super slipperiness of the synthetic oil may allow for some of it to pass over the piston rings and be burnt up. If your GTI drinks a bit of mineral oil, it’s going to use more synthetic oil imo.
    Transport mode has the Golf restricted to 4,000rpm.
    4,000rpm max revs for run in period is not that far from 5500rpm, where it’s advantageous to change up gear in the GTI as turbo boost is trailing off.
    95 degrees for time of year in Sydney seems to be the lowest easy driving temp for the TSI motor. So 95 degrees is what I'd be aiming for prior to leaning on the TSI motor.
    Cheers.
    WJ
  6. #126
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by pologti18t View Post
    I start the car, put my bag in the back, get in the car, and do the rest like you. By the time I've done those things, the idle drops... so it's only a 30 second thing
  7. #127
    Feb 2009
    Cheers WJ.
    Quote Originally Posted by ddre78 View Post
    I'll have to take more notice, you are probably right!
  8. #128
    Adelaide hills, SA
    Here is why you should still idle the engine before you switch it off after long hard drive.
    It used to be 70 deg. for mineral oil for the anti-wear additives to be active. But modern synthetic oils should protect the engine right from cold.
  9. #129
    Feb 2009
    Nice thread you have there! I think if you take it easy driving home for the last few minutes for example, and leave the engine idle for a minute or so should be ok. Around town isn't really like doing laps on the track (for me anyway).
  10. #130
    May 2010
    Out of interest, what make & model is your girlfriends car? And how long does that blue light stay on for a typical cold start?
    Its just a Mazda MPS, 2009 model. It stays on for about 3 mins then turns off when the car is warm.. I guess enough. to go?
    2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
    2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
