I'd expect that driving in Sport mode will just annoy you very quickly. In my experience, it'll rev higher than is comfortable for everyday driving. AFAIK, higher engine speeds aren't what you should be aiming for during the early stages of run-in, but rather varying the engine speed regularly, to ensure matching/consistent/smooth surfaces between the various moving parts.
Push the lever to manual and do the gear shifting yourself from time to time. Drive the car gently but don't baby it completely, and if you're cruising along straight stretches of road without undulations (for variation in engine load), or changes in engine speed, then just shift down a gear or two for a couple of minutes, and then shift back. Rinse. Repeat.
I'm only going to be doing the above for the first couple of thousand km before I pay less attention to it; by that stage the parts should have machined to each other nicely. Then it'll be time to start increasing the maximum engine speed and throttle load. By 5,000km I'll probably give it the full welly occasionally.
This sounds good. I'll definitely give the 'manual' shifting a go and will take the car on a nice varied drive for a couple of hundred kilometres on the first weekend, as a lot of the regular driving in this car will be on a long straight flat road at 100/110 km/h and will be the Mrs behind the wheel for those trips.... not too sure she'll be keen to do the shifting herself, so may suggest she take a different route for a couple of weeks.
Guys my dealer told me the engine was broken in at the factory and that i can go ahead and drive it how i want?..
2010 5 DR MK6 GTI|DSG|CARBON STEEL|18" DETROIT|ACC|BI-XENON|LEATHER|SUNROOF|DYNAUDIO|SATNAV|MDI|PREMIUM BT|TINTS|EXTENDED WARRANTY| In garage
That contradicts what the factory manual says. One is in writing & the other verbal. I doubt the salesman would stand behind his advice if something went wrong.
I'd have no problems driving my car "normally" straight from the showroom but there are some tosspots out there with little mechanical sympathy that would probably push too hard at the start.
Basically what he told me as well, and it wasn't the salesman, it was the service department guy.
But yeah i have reved my car to like 7000 rpm a few times in sport mode. Time will tell i guess if my car fracks up sooner then all yours.
MK7.5 R|Lapiz Blue|DAP|Sunroof|Tint
SOLD MK7 GTI|DSG|Carbon Steel|Leather|Panoramic Sunroof|Bi-Xenon Lights|Driver Assist|Tint|Euro Plates
SOLD MK6 GTI|5 Door DSG|Carbon Steel|Leather|Sunroof|Electric Driver Seat|MDI|Tint
You should be able to feel the engine going tight - like it doesn't want to rev. I just kept taking mine to that tight point momentarily in 2nd or 3rd, then backing off for a bit & doing it again. It only takes a decent drive of a couple of hundred kms to get to the point where the engine feels reasonably free & responsive.
