Revs and Load:
Varying the revs enables the motor to be on and off load. On load: the motor will develop friction heat. Off load: allows the motor to cool. In the case of highway driving, the revs may not vary a great deal, but gradients will vary in many cases which varies the load on the motor. Going up rises loads the motor up; driving downhill unloads the motor. I wouldn’t be too concerned with varying the revs if you have to drive freeway miles, as long as the vehicle is not driven at a constant speed & load.
Temperature:
Intercooled turbo motors love cool air. Running in a motor on a hot day in peak hour traffic is not going to do much for keeping intake temps cool & reducing friction heat. Best take a long scenic route drive up the mountains to somewhere cold with plenty of opportunity to put load on/off the motor. Cool air feeds the internals to reduce the heat caused by friction. The longer the first few drives, the better imo as it saves on the heat up and cool down periods. Short infrequent stop/start drives may not allow the motor to rise up to its correct operating temperature, hindering the mating process.
High Revs:
Higher revs in a turbo motor may induce piston-ring flutter, possibly scorching the bore, which may lead to long-term excessive oil consumption. This is why you want to avoid high revs as the owners’ manual indicates. The Mark 6 GTI has stronger piston-rings than the Mark 5 GTI, but I’d still be keeping the revs under 75% as the manual states.
Thrashing motor from the outset:
Thrashing a motor is never a good idea unless you’re race car driver who rebuild their motors frequently. Start the run in process gently and gradually increase revs to a higher crescendo after the 1500km. If your motor is tight at 15,000km, it will be tighter at 150,000km.
Oil Change:
Being old-school, I believe that an oil change at 1500km is worthwhile. The service managers are constantly indicating that the type of oil used for run in period on Volkswagens does not require an initial oil change until 15,000rpm as recommend by the service manual. In addition, the motors are supposed to be bench tested. Not sure how well bench testing replicates a real world scenario with constant gradients or additional weight of passengers on board. This advice has me in two minds.
Cheers.
WJ
