Page 1 of 40 12311 ... LastLast
Results 1 to 10 of 393
Thread: Tips for breaking in a brand new engine?
    Mar 2010
    Ashgrove Brisbane
    Hey guys,
    I started another thread with this question in it however i thought it was worth starting a thread specifically dedicated to the topic as there seems to be mixed opinions.
    What are your tips to breaking in a new engine of a GTi or Golf alike?
    Please share any opinions and or do's and don'ts.
    Mar 2007
    sydney
    comes with warranty so give it hell, run in hard always go hard ......
    mk4 the mods begin for round 2 hahahha
    Mar 2010
    Ashgrove Brisbane
    Not sure if i feel comfortable with slamming my new $45k car
    Feb 2010
    Whatever you do, don't baby the new car...either treat is as per normal or even perhaps work it hard. It is under warranty and you want issues to surface and be fixed while it is.
    Feb 2010
    VIC
    Is there any specific guideline from the manufacturer as to how one should wear a new car in? By 'not babying' the car, do you mean just normal day-day driving but not taking it to redline etc?
    As for the working the new car in and not 'babying' it in its first 1000kms, possible its a bit of a catch 22, if you wore it in properly at the beginning instead of thrashing it from the start, perhaps those problems wouldn't have developed in the first place? Either way, the new car warranty is for 3yrs / 100,000kms, even if you baby it in the first 1000kms, there's still another 99,000kms left for the potential problems to surface. So its not like you're shortchanging yourself by doing so.
    Canberra
    Plenty of existing threads on this (and plenty of opinions too !).
    Here are my opinions:
    Don't ever allow the engine to idle to warm up before driving (this is the absolute best way to glaze the bores), just drive gently until the engine is warmed up properly (this applies to ALL engines, new or old)
    I like to vary the engine revs all the time (so no cruise control at all) for the first 2,000km, lots of mid range accelerator pedal under load (more pressure on piston rings to help them bed into the bores better), and increase max revs over the first 2,000km.
    After that just vary the revs a bit if cruising for the next 2,000km, otherwise drive as normal once warm.
    Check the engine oil level regularly, as some engines use a bit at first. If you need to add some make sure it is VW 504/507.
    Don't switch the engine off straight away if you have been working the engine hard (the turbo will be red hot). Best is to drive gently for the last 5 minutes of any journey, but if you cant, let the engine idle for a couple of minutes before switching off.
    Jan 2010
    Sandhurst, Vic
    The dealer told me to drive it like I stole it, definitely don't baby it because it will forever be a slug. I have driven my GTi hard from the outset but just avoid doing so before warmed up and ensure cool down cruise before shut down.
    Got a 6.4 0-100 the other day so it's working!
    Baby it at your peril!
    2010 Golf GTi 5 door, DSG, 18" Detroits, MDI, BT
    2010 BMW X5 xDrive 30d
    1969 Datsun 1600 club race car 13B bridgeport 203 rwhp
    Nov 2008
    Just my two cents, and Also im bored,
    I know with bike engines, the first 500-1000kms, you should be very easy on the motor, dont thrash it, just nice and quietly about the place. The following 500kms, start to work the motor a bit, building up revs, changing the gear box, (When I say build up revs, be driving along at 60, doing 2k, change back to 3rd, do 3k, back to second do 4k, so on so forth, just dont rev the ring out of it) I had a salesman tell me just jump on a bike and thrash the **** out of it, it will be right. 20kms up the road, I called them to come pick me up as the motor had packed up. Salesman dont know **** most of the time. I'm sure there is the exception, but generally. I agree with Dracz a bit here too, If you dont give the thing **** while its still new, things might not pop up. Might.
    As for being forever a slug, Im sure the mk 5 or 6 or what ever it is, has a learning ECU, or what ever it is that they are called. My vr has certainly changed with power delivery as I have driven it over the last 40,000 odd kms. It seems to be alot more mid ranged and now is doing roughly 110 km/h in second gear. I tested that theory on the 110 zone going north.
    Anyway as I said, its all opinions, and thats mine
    and why is this forum banning the word C R A P all of a sudden?
    Coxy
    "Some people dream of achieving greatness, other people get out of bed and do it"
    Feb 2010
    Quote Originally Posted by DracZ View Post
    ...but not taking it to redline etc?
    Redlining it is perfectly fine if the engine is warmed up already. In fact you should redline it at times.
    ...if you baby it in the first 1000kms,
    you end up with a slug.
    Nov 2008
    Quote Originally Posted by markwid View Post
    If you redline a new motor, you will damage it, Ask some of the mech's at Austral or your local dealer, provided that they have been working as a mech for a few years, they will say dont redline a brand new motor as it will F**k it.
    its a learning ECU, they will change over the driving period. You can re-set it to factory settings too.
    Just for light reading
    http://www.answerbag.com/q_view/2420
    http://www.cartalk.com/content/colum...tember/02.html
    http://www.discovery-automotive.com/...e=content&id=6
    http://www.lambopower.com/forum/inde...&mode=threaded
    http://myfastgti.com/volkswagen/show....html?p=123373
    (I particularly enjoyed the second post on that one, with what the Manual says)
    Happy reading
    Coxy
