Page 37 of 40 FirstFirst ... 273536373839 ... LastLast
Results 361 to 370 of 393
Thread: Tips for breaking in a brand new engine?
  1. #361
    Nov 2009
    And now, back on topic... *hint hint*
  2. #362
    Mar 2008
    Sunshine Coast
    On this topic of "drive it like you stole it", what are people doing when they get an off the shelf tune applied ?
    I know with Subies I had, post dyno tune, I followed directions from the tuner on how to drive the vehicle for a few tanks of fuel.
    I imagine this applies even more to off the shelf tunes.
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
  3. #363
    Erskineville, NSW
    Quote Originally Posted by Rawcpoppa View Post
    After reading through some of this thread I am still confused. Just got a new 1.4 tsi Jetta 118kw and the vehicle manual does not specify how to run in the engine/vehicle.
    Yes it does. Look harder. Salesdroid should have also provided advice on running in & regularly checking oil when they did the handover.
  4. #364
    Apr 2012
    Ive always used the motoman method.. used it for years now. I even use it on my r/c cars. Never had an issue.
    Im curious as to what Suby tuners your talking about Candy .. Spiro or Nick or Paul or Wymms? I hope it wasnt the hub fool?
  5. #365
    Mar 2008
    Sunshine Coast
    Paul (and backed up by Spiro)
    Drive it like you stole it makes no sense unless you stole it.
    Not with today's engines
  6. #366
    Oct 2012
    Are Golf MK6 factory run-in?
    Hi all,
    New to the forum and to the world of VW having just picked up a new MK6 Golf GTI DSG. Loving it so far but I've been a bit wary of pushing the revs too much. 500km on the clock now.
    So are GTIs run in at the factory these days? I've read/heard many different answers to this and was wondering if anyone has a categoric answer. I've done about 500km so far and have been a bit hesitant to hit the revs too high just yet.
    Cheers,
    Otto
  7. #367
    Dec 2008
    Sydney/Canberra
    The book says to take it easy for the first 1,000klms. Beyond that, drive it however you like.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  8. #368
    Jan 2010
    UK Cheshire
    Its a www myth about running in at the factory. They whack the engine on the dyno on the factory line for about 15 seconds total, slam the engine to high revs more or less instantly, if it runs and makes 60%ish of its deigned power/torque, they crate and ship to the car assembly plant. Stood there and watched the painful birth they get! Do not remember cooling being connected, just fuel & electrics necessary to run the engine.
    You follow the owners handbook to bed in the components of which, engine, gearbox, brakes and suspension all need to be gradually bedded in. They tell you the engine but thats the limiting factor which all the others listed above need the same treatment. Gentle at first, progressively getting normal through to finally full on.
    VW SCIROCCO 1.4TSI - DSG (MY2010) UK, East Cheshire.
    Build Complete October Wk43/09, Driving 4th November - Wk44/09. Sorted !
  9. #369
    At the end of the production line @ Wolfsburg, they run the cars on a set of rollers at full throttle in every gear (hitting the rev limiter - brutal) then several brake tests (must be big inertia rollers).
    When we asked about the procedure, they told us if they dont make within 2% of the stated power output, the car is returned to the production line & the engine swapped out.
    It also give all brake components a good pressure test.
    Believe me, go do the production line tour - it's totally amazing from start to finish, and watching them do this test, you will never bother "running in" a car softly ever again!
  10. #370
    Mar 2008
    Sunshine Coast
    Good to know their equipment is all over the place like dynos here ....
