Page 33 of 40 FirstFirst ... 233132333435 ... LastLast
Results 321 to 330 of 393
Thread: Tips for breaking in a brand new engine?
  1. #321
    Quote Originally Posted by cavinsoo View Post
    Would tracking a brand new Golf R be a good idea to break it in? Not going to push it to the max but at least there are chances to drive it fast and on all gears.
    No worries at all.
    I've taken brand new motorbikes from the shop straight to the track before, it's a great place to break in new engines. Just make sure to check your oil regularly.
    I prefer to run all my engines in a bit harder than your average Joe (whilst still showing mechanical sympathy)...
    MKV Golf 2.0 TDI DSG Sportline. Just nice.
  2. #322
    Erskineville, NSW
    Start at 5/10ths & work upwards. You should feel it as it gets tight. Keep in mind you are also breaking in gearbox, wheel bearings, brakes, etc
  3. #323
    Sep 2011
    Blackburn, VIC 3130
    Thanks, Brad. But what do you mean by "Start at 5/10ths"?
  4. #324
    Erskineville, NSW
    Like 50% throttle or if a corner can be done at 100kmh then early medium brake & tip in at about 50-60kmh.
    The best way I can describe it is imagine you have your Dad's car & he is in the passenger seat & you're trying to prove to him that it's safe to use his car at a track day.
  5. #325
    Sep 2011
    Blackburn, VIC 3130
    Right. Just take it easy. Got it. Thank you very much~
  6. #326
    Jun 2011
    Perth
    Quote Originally Posted by Candyman View Post
    After that, it is case of not abusing the vehicle, good maintenance and common sense.
    And when it comes down to it, an owner must assume that what the DSG allows is OK for the engine. I am surprised that the DSG in S allows the revs to come to 7500rpm... but it does. Which, once every couple of weeks, helps me surprise a HSV. But it's only every couple of weeks.. normally i'm just late, and late only means 6000rpm
    MY11.5 5dr GTI // Carbon Steel / DSG / Detroits / RNS510 / Bluetooth / Euros
  7. #327
    Feb 2010
    Oil usage at 27,500km?
    The Mark 6 Golf GTI is not far off clocking 27,500km. Only one service since new - 15,000km scheduled first service only. In others words, that's 12,500km since last service.
    Oil usage - None.
    That is despite a few short trips in the colder winter months. Very happy about this. Who said that the EA888 motor drinks like a siv?
    Cheers.
    WJ
  8. #328
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by WhiteJames View Post
    EVERYONE who's ever taken it to the track
  9. #329
    Erskineville, NSW
    Cheers.
    WJ
    Probably nobody. It's leaks like a sieve or drinks like a fish/russian/lush, etc
    I believe the EA888 is quite civilised under normal use but if you track it, the CV system is overwhelmed & the oil disapears.
  10. #330
    Feb 2010
    Oil usage
    30,000km service has come up with Golf GTI now 18 months old. So far no oil used, which is great. Pays to keep a light throttle, rev ceiling of <4,000rpm for the first 1500km and drive plenty of hill-climbs like Macquarie Pass and Kangaroo Valley in the first 1500km break in phase for plenty of load on the motor. Be kind to your GTI and it will look after you. Correct me if I'm wrong - I think the only GTI's using oil are the chipped up versions that are driven on the track.
    Cheers.
    WJ
