Page 18 of 40 FirstFirst ... 8161718192028 ... LastLast
Results 171 to 180 of 393
Thread: Tips for breaking in a brand new engine?
  1. #171
    Jan 2010
    State of Denial
    I'm going to cover radiator grill on our new Tig for running in period since it's cold in the morning and it takes forever to warm up the engine.
    Don't forget the engine bay needs some airflow around local hot spots but if you are doing short distances and driving gently it should be OK. How about not using the cabin heater
  2. #172
    May 2007
    Jimboomba. QLD
    Quote Originally Posted by coreying View Post
    Hey Cossor, I'm not sure that the 118TSI has an oil temp display in the MFD (can anyone confirm that?), so you may not be able to actually check what your temps are getting to. The temp display that is found in most cars these days, including the 'regular' Golfs is the water temp.
    I have a 90TSI (with comfort pack and therefore the MFD) and it has oil temp.
    2010 90TSI Manual / Comfort Pack / United Grey
    RICE - Leave the useless wings to the Penguins...
  3. #173
    For info I watched the temps on my drive home from work this morning. Car had been parked outside all night, I drove home at 6:30am when it was 10 degrees outside.
    It took the water 7 minutes to settle on 90.
    It took the oil 7 minutes to reach 50, 9 to reach 60, 11 to reach 70 and 13 to reach 80. The oil peaked at 84 on the 27 minute drive.
    2010 MY10 Golf R (Sold) - 5 Door, DSG, Rising Blue, Leather, ACC, Satnav, Dynadio, Sunroof, MDI, Electric Seat.
    2015 MY16 Golf GTI - 5 Door, DSG, Carbon Grey, Leather, Sunroof, DAP.
  4. #174
    Mar 2010
    Witness Protection
    Quote Originally Posted by HPSOV View Post
    This matches my experience of the R in that it operates in colder temp range than the GTI (around 5-10 degrees) and due to its heavy duty oil cooler set up the oil temperature drops far quicker when hot.
    Quote Originally Posted by WhiteJames View Post
    Sydney:
    I did an easy drive through the Royal National Park (RNP) with 60-80kph zones to ensure all the parts get to know each other for the first 150km. Oil temp usually hovers around 96 degrees, indication not much load on the motor at all.
    Second drive involves the freeway with higher speeds & high engine loads with a mountain climb up Macquarie Pass to Moss Vale & return to Sydney, either the same way or in a loop through Mittagong to Picton Road, doubling back onto Mount Ousley and just north of Wollongong (Princes Freeway) for the return journey to Sydney. Saw oil temps range from 91 degrees to 109 degrees on last drive from Sydney to Kangaroo Valley – Moss Vale.
    Yesterday I did the RNP and Macquarie Pass run in the GTI to help the run in process and had a ball.
    Going up Macquarie Pass and keeping to a 5000 rpm limit saw the oil temp go from 96 degrees to 105 degrees max - this was whilst having plenty of fun in the bends but sticking mainly to 3rd gear.
  5. #175
    Nov 2009
    Quote Originally Posted by hooba View Post
    So, just out of interest - is an oil cooler upgrade for the GTI a worthwhile mod? Would it be difficult and/or costly to do? Would you go the Golf R cooler, or some other aftermarket equivalent? (Eg does APR offer one?)
  6. #176
    May 2010
    Melbourne, Victoria
    To all the Watercooled users who live in Melbourne and purchased their vehicle from Philip in the ACT (also to the rest of you who know these roads better).
    Which route did you go, via the Hume Hwy/Hume Fwy or via Monaro Hwy/Princes Hwy? Are there better alternatives/side roads (sealed is prefarable, do not want gravel/stone chips) which will better for breaking in the engine?
    Just trying to plan out my preferred route. Any discussions and suggestions would be appreciated.
  7. #177
    Feb 2009
    Sydney, Australia
    Actually - there some AWESOME roads in the Snowy Mountain area heading out via the Monaro Hwy. WhiteJames seems to have a good grasp of "driving roads" even in the ACT, so maybe he can help.
    I remember I once exited Canberra heading south on the Monaro Hwy, then went across the Snowy Mountains over a beautiful road across the top of a dam and then some how still made my way through the North entry to Albury Wodonga. Unfortunately it is back in the day before GPS or google maps and I was literally just "driving in the general direction" of Melbourne, lol
  8. #178
    Some of these roads (teh ones that cut across the mtns off the Snowy Mtns Highway) will be (or could be!) shut during the snow season. Best to check on the National parks site.
    If you just want to get back to Melbourne without using freeways then you go from Canberra to Cooma, then down the Monaro Hwy to Cann River. NOt the most challenging road but it isn't chockers full of traffic so you can set your own pace.
    If you want some additional challenges then try heading for the coast at Bombala (signed to South Pambula or Eden I think)
    BE WARNED: It's the ski season so the roads around the ski fields will be infested with highway patrol. I would also assume at least one mobile camera will be lurking around (probably at Bredbo, a 60km/h zone). In the Polo I can get away with an indicated 110 in a 100 zone without stirring the cops' attention.
  9. #179
    May 2010
    Melbourne, Victoria
    I should be receiving my car November/December so no need to worry about snow season (assuming there is no great hollywood-like asteroid fallout causing an impact winter). So it is a while off, but nothing wrong with a bit of pre-planning
    The highway driving is a bit of concern, but quieter roads where I can vary my speed easily would be great.
  10. #180
    Mar 2010
    Witness Protection
    Quote Originally Posted by AdamD View Post
    I wouldn't bother unless you where getting into serious mods / HP.
