Thanks for the info Transporter. So that explains why all car manufacturers require their cars to be serviced in shorter intervals if the car is subject to lots of idling, because the oil goes to crap quicker!
Yeah, I turn my car on, and as soon as the idle has dropped from ~1000rpm to ~700rpm, I gently drive away. As far as I'm concerned, you don't need any light - that's how VW is letting you know the car is ready to drive away![]()
I noticed on the MK6 the oil temp doesn't display a figure on the MFD for a while (~5 minutes). What is a reasonable operating oil temp when you can start caining it? 70-80 deg?
Not much point in having the Golf sitting stationary idling. They’re built to be driven straight away. Driving off ASAP allows oil pressure to build up & a bit of friction also generates heat. Best not to rev it much more than 2500rpm for GTI, not until the coolant & oil come up to temps. I leave the DSG in Auto until temps warm up. We’re not taxi drivers that keep their cab motor warm 24/7 and achieve up to 500,000km from a motor.
The driver’s manual states that after working the motor hard, whether it be high revs or excessive load, the driver should idle the motor for 2 minutes to allow temps to normalise prior to switching off the motor. I like to coast in Auto and for this time of year, try to have engine oil temp drop to 95 degrees Celsius prior to shut down.
The MKV/MKVI GTI motor does automatically run the pump & fans after shut down to cool the motor as no air is circulating around the engine bay. The owner’s manual indicates this.
In the 1980’s, the Nissan Turbo Group A and earlier Nissan Skyline Turbo race cars would have the turbo give up after the first pit stop. In racing, the motor has to be shut off for the pit stop, and in those 30 seconds, the engine bay temp sky rocket without any air-cooling, causing damage.
The owner’s manual also states that when put in neutral, the DSG gearbox oil pump switches off. Never coast the DSG GTI down a hill in neutral – the gearbox will seize from lack of oil.
The DSG is designed to be a sealed unit with wet clutches that should last the life of the motor. Wet clutches are designed to slip.
The run in period for the MK6 GTI is 15,000km. This is the phase where mineral oil has to be used. Dealer gave me a warning in case I was going to do a DIY oil change between services.
I found that once you change to synthetic oil, the GTI uses a bit more oil. The super slipperiness of the synthetic oil may allow for some of it to pass over the piston rings and be burnt up. If your GTI drinks a bit of mineral oil, it’s going to use more synthetic oil imo.
Transport mode has the Golf restricted to 4,000rpm.
4,000rpm max revs for run in period is not that far from 5500rpm, where it’s advantageous to change up gear in the GTI as turbo boost is trailing off.
95 degrees for time of year in Sydney seems to be the lowest easy driving temp for the TSI motor. So 95 degrees is what I'd be aiming for prior to leaning on the TSI motor.
Cheers.
WJ
Here is why you should still idle the engine before you switch it off after long hard drive.
It used to be 70 deg. for mineral oil for the anti-wear additives to be active. But modern synthetic oils should protect the engine right from cold.
2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
