Results 1 to 8 of 8
Thread: Thoughts on the Mk6 103TDI
    Mar 2020
    Bendigo, VIC
    Hi Guys
    Looking to upgrade my car soon (I currently have an 06 Ford Fiesta LX) and I'm actively considering getting the MK6 103TDI Golf and i was wondering what the general opinion on the Mk6 103TDI was - I'm also considering the Mk5 6R VW Polo 77TSI, though given i have an occasional heavy foot I'm thinking the Mk6 103TDI is the better option - Thoughts? and if you've owned one before what do you think of it?
    James
    Dont buy a TDI unless you regularly drive for periods of time on the freeway or open road, they dont like city stop/start driving.
    Pacific Paradise QLD
    ^^^^^^^^ Definitely this
    I had a Passat diesel and only ever used it on trips where it got hot for a while , like more than 30mins each way
    Our Polo doesnt disappoint and have had it up to 140kph and it wasnt flat. Keeps upon the highway no trouble
    Not quite the smooth ride the Golf would have but have done a 1000km trip without discomfort
    Mar 2020
    Bendigo, VIC
    I do quite a bit of both - Especially with how many Roadtrips i go on - Usually a couple a year and they go on for a few thousand kilometers
    If you use it to commute under 15 k a day and only do a trip of 100km less often than 2 monthly I wouldnt buy one again for that sort of use.
    Mar 2020
    Bendigo, VIC
    When i was working (and i will be again shortly) - I was averaging 500 - 700km a week - I'll likely be doing the same with my next job - I've done 71,000ks over the past 3 years with my Fiesta so I do travel quite a bit
    Quote Originally Posted by Jimithy777 View Post
    I guess the same principal applies, if those km's are longer drives on open road/freeway then yes, if they are lots of short drives in start/stop traffic I would strongly suggest not buying a diesel.
    Apr 2017
    belgrave victoria
    Hi Guys
    James
    Hey mate
    I had a 2009 mark 6 tdi for 8 years and gave it to my daughter who has had it for 3 now
    It has 165k on the clock in that time the only thing to go wrong is the radio/infotainment unit which gave up the ghost 6 months ago
    Apart from that a new windscreen and rubber boots for the cv joints is the only things apart from normal service items that i have spent money on
    Still going strong and radio aside every switch and knob still works fine the cluster between rev counter and speedo does not have 1 missing light ect ect
    Make sure it has good service history i.e gearbox oil and filter every 60,000k this is expensive($400-$500) so many skip it timing belt at 105,000k and a oil and filter every 15,000k
    It,s a good solid car i really enjoyed driving it if maintained it will keep on going and going
    If my daughter did not require a car at 18 i would still be driving it myself
    Good luck finding a good one
    As for driving i drove about 450km a week about 25 min a time to work and back if you know melbourne it was from oakleigh to south dandenong so if your commute is anything like that should be fine
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
