I don't know about the GTD but on my TSI, the up and down adjustment makes a big difference to how the lights project.
Have a new GTD and I am delighted with it except for one thing-----Headlights are s--t.
Drove through the hills at night last week and was quite nervous, cos I could not see properly. When on high beam, there is an unlit area between the low and high projection.
I will be complaining to the dealer and asking for it to be fixed, but fear it's the breed of the beast. Do others share my grief?
2010 90TSI Manual / Comfort Pack / United Grey
RICE - Leave the useless wings to the Penguins...
Can't say I've noticed it.
There's an adjustment on the dash for the low beam (at least there is on mine) — maybe it's set too low?
If slightly better halogen bulbs don't do it for you, then extreme measures are possible.
At least a couple of MK6 owners have broken open their lights and installed projectors and xenons.
adding HID projector retrofit on mk6 Golf - VW TDI forum and Audi TDI forum - myturbodiesel.com
Bizi's Jetta TDI: Blue Graphite w. factory leather & tint, plus + Enkei Racing NT03+M + Yokohama S Drive 18s, Koni FSD, Neuspeed coils, GTI RSB + brakes, InPro mirrors, VW navi, Modshack. Come for a drive through the twisties on Saturdaze.
Check out Winedriving forum/news for driving trips and wine tips.
also, for the halogen headlights, you can't go wrong with either of these:
Philips X-Treme (Extreme) Power
Car Bulbs, Headlight Bulbs, Xenon Bulbs from Philips and Osram, Philips Xtreme Power, Osram NightBreaker globes - Powerbulbs.
OSRAM Night Breaker PLUS
one of the cheapest upgrades to improve visibility at nights for Mk6 Golf
Yep, three things (all mentioned above)
1) Make sure YOU have adjusted the headlight distance (to the right of the steering wheel).
2) Ask the dealer to ensure they are aligned properly if still unhappy
3) Change to one of the aftermarket bulbs mentioned by nat225.
But do not put in aftermarket HID conversions... they're illegal in this country.
You also then need to install the sensors for the auto leveling, and the motors for that etc.
All the required parts end up costing more than it did to option them from the factory....
Thanks for all of the replies, but I need to bring the beams together so that I eliminate the black area. I think it's a reflector issue, so I doubt wether changing globes would make a difference Niether the adjuster near the steering wheel or the white screw do this. There must be a trick, but I can't find it.
