Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Terrible headlights
    Feb 2009
    Sydney, Australia
    The headlights are great (for non-Xenon), so I would assume that your car has an adjustment issue that could be resolved by your dealer.
    Quote Originally Posted by REGS12 View Post
    Thanks for all of the replies, but I need to bring the beams together so that I eliminate the black area. I think it's a reflector issue, so I doubt wether changing globes would make a difference Niether the adjuster near the steering wheel or the white screw do this. There must be a trick, but I can't find it.
    There should be a dial near the master headlight switch. usually has 0 (or -) ,1,2,3 on it. Set it to 0.
    If I am not mistaken... the height adjustment affects both the main beam and high beam to the same degree.
    Jul 2010
    Gympie Queensland
    On my Jetta TDI I can "play" with the light adjuster to the right of my steering wheel to make the "black " area as you describe, appear or disappear. Maybe your lights might be out of "standard alignment".
    Nov 2009
    Cook, ACT
    headlight aim can be adjusted with a screwdriver at the light. There are rules about where they point, especially height.
