Hey mate, I removed the intake due to what seemed to be a fuel trim issue when I tuned the car with Superchips Bluefin. It would hesitate as soon as I hit boost at around 2400rpm. I put the stock box back on and it was perfect. I run the BSH intake now with no issues..... Except for this low rpm/light throttle stumble.
Carbon build is a possibility but I had a new intake manifold fit and I still had it but not sure how bad the valves were. I thought carbon build up would cause misfires when cold, I have no misfires when cold and it idles perfect, it's just when I add a little throttle it starts to stumble and then I go passed 1500rpm it's smooth as. I cleaned my throttle body but it wasn't dirty at all when I took it off. So it's either the car doesn't like rpms from 1000 to 1500rpm or it doesn't like the throttle position at these rpms.
Good luck everyone.
