Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 82
Thread: Sports Pack
  1. #31
    Sep 2009
    As far as I am aware, ACC utilises an electro-mechanical dampering system (as opposed to magnetic ride) and on the sports mode prevents the car from rolling too much, giving the perception of more direct steering. I really don't think they have steering profiles per-say.
    Jetta MK6 147TSI DSG Reflex Silver
    Pondering: too many to list...
  2. #32
    Aug 2009
    Melbourne, Vic
    I just reviewed my research and I should have said steering maps not profiles.
    "Aside from the muscular and efficient new TSI engines, arguably the most important mechanical change inside the new Golf VI is the use of adaptive dampers. VW calls the system Adaptive Chassis Control but label it, confusingly, DCC. The system incorporates alternate steering maps for the Golf's new electromechanical steering but most of the trickery is in the electronically-controlled dampers.
    DCC-equipped Golf models ride 10mm lower than the conventional cars and feature a Monroe-sourced damper system that uses an Ohlins-supplied magnetic valve block to automatically control pitch and roll when cornering, accelerating and braking. To do so the system interrogates a range of sensors across the car including steering, engine, DSG transmission, braking and other systems, including stability control et al.
    Three settings are offered -- Normal, the default setting; Comfort and Sport -- and changed via a simple console mounted switch. The last setting used is 'saved' and automatically reactivated at start.
    In Sport mode, the Golf's steering is also firmed up."
    and from another source..
    "The memory has capacity for up to 16 differnt maps. In the Golf 2004, for example 8 of the total available maps are used. ...... Maps are activate in the factory depending on requirements....... However, Maps can be activated in a service center using VAS 5051" or VAG-COM no doubt.
    Oh and J-Tim, I realise you cannot select ride with the Sports Pack. Just wondering if Sports Pack has a different steering map assigned in the same way as the ACC option does.
  3. #33
    Sep 2009
    nice! now where did you get this nugget of information?
  4. #34
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by thamwk View Post
    First part I just googled and found at Carpoint. By a motoring journo I guess, so not definitive. Second part is from the VW electro-mechanical power steering self study guide, which has other gems in it like how
    - the system alleviates side force driving in a crosswind.
    - operates without the engine running when speed > 15kph. Try it rolling down a slope - it works.
  5. #35
    Mar 2009
    Melb
    This are the codes I draged out from my car, a 118 TSI with sports pack. Compare if you like the codes and see if it will make a difference.
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (CAV) Labels: Redir Fail!
    Part No SW: 03C 906 027 G HW: 03C 906 027 F
    Component: MED17.5.5 G 3428
    Revision: L1H08--- Serial number:
    Coding: 0000077
    Shop #: WSC 01357 011 00200
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: Redir Fail!
    Part No SW: 0AM 300 046 C HW: 0AM 927 769 D
    Component: GSG DSG AG7 402 1014
    Revision: 40024 Serial number: 00000812180965
    Coding: 0000020
    Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
    Component: ESP MK60EC1 H35 0106
    Revision: 00H35001
    Coding: 163B600D21280003680C06E7841D0080B500
    Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
    Part No SW: 5K0 907 044 AJ HW: 5K0 907 044 AJ
    Component: Climatronic 130 0305
    Revision: 00002001
    Coding: 0000000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Climatronic A01001
    ROD: EV_Climatronic_VW36.rod
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 1K0 937 086 HW: 1K0 937 086
    Component: BCM PQ35 M 020 0358
    Revision: 00020000
    Coding: 40180A3A902518C044080080140081E441510088436D896064 8000000000
    Part No: 1K2 955 119 E
    Component: Wischer 27110 21 0501
    Coding: 009795
    Part No: 1K0 955 559 AH
    Component: RLS 111208 05 54 0402
    Coding: 0330AD
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5K0 959 655 HW: 5K0 959 655
    Component: AirbagVW10 022 0507
    Serial number: 003C2D06W5L8
    Coding: 00003134
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01003
    ROD: EV_AirbaVW10SMEVW360_VW36.rod
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
    Component: J0527 055 0111
    Coding: 0001532
    Part No: 3C8 959 537 B
    Component: E221__MFL-TAP H4ÿ 0021
    Coding: 00000226
    Shop #: WSC 00000
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K0 920 870 B HW: 5K0 920 870 B
    Component: KOMBI H21 0029
    Serial number: 00000000000000
    Coding: 170B00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
    ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 S HW: 1K0 907 951
    Component: J533__Gateway H16 0210
    Revision: H16 Serial number: 3400K08C0302F0
    Coding: ED807F06400202000003
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Component: IMMO H21 0029
    Serial number:
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
    ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
    Address 37: Navigation (J0506) Labels: 1T0-035-680.lbl
    Part No SW: 1T0 035 680 C HW: 1T0 035 680 B
    Component: RNS-MID H02 2660
    Revision: AB001001 Serial number: VWZ6Z7H8151085
    Coding: 04000400040000A200
    Shop #: WSC 01316 785 00200
    ASAM Dataset: ------------------------- ------
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 AM HW: 1K0 959 701 AM
    Component: Tuer-SG 008 2016
    Coding: 0000692
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K0 909 144 E
    Component: EPS_ZFLS Kl. 69 2501
    Revision: 00H15000
    Shop #: WSC 01324 785 00200
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 AM HW: 1K0 959 702 AM
    Coding: 0000692
    Address 56: Radio (J0506) Labels: 1T0-035-680.lbl
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 AL HW: 1K0 959 703 AL
    Component: Tuer-SG 007 2009
    Coding: 0000144
    Shop #: WSC 01357 011 1012552
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 AL HW: 1K0 959 704 AL
    Coding: 0000144
  6. #36
    Aug 2009
    Melbourne, Vic
    Thanks for that mr gee. Thats Gold. Doubly confirms my suspicion. Same part no for both the ABS units and ABS controllers on both car configurations. That only leaves the TPMS switch being fitted and the ABS unit coding as being different. While it is tempting to simply place your coding into my ABS controller, I suspect the 6 differences between the two codings tag more than just the TPMS being active.
    Coding: 163B600D212A00FC681106E884220080B100
    Different tyre sizes for starters. But sure leaves me with something to ponder and work with. Will report back I make any progress. Thanks.
  7. #37
    Apr 2009
    Smile
    Quote Originally Posted by J-Tim View Post
    Just wondering what other suspension modifications are included in Sports Pack, besides lowering coils ? Thicker swaybars maybe ?
    Sports pack is really worth the 2K. The seats are in my opinion the best in the business. One other thing is the option of the adaptive chassis control is only 1k extra instead of a 1.5k stand alone option when ordered with the sports pack. Go on, spend the extra, it will only hurt once and you'll never regret it.
  8. #38
    Nov 2009
    Rowville, Vic
    Question Lowered - yes or no?
    Has anyone found out for sure whether the Mark 6 tsi with sports pack is lowered or not, and if so by how much?
    When I looked at one at the dealership (next to a model that didn't have it), it looked to me as if it was......
    Eyes playing tricks?
    ~Nic~
    Deep Black Mark VI Comfortline 118 tsi - manual/sports pack, MDI
  9. #39
    Mar 2009
    A Sports Pack Mark 6 is definitely lower, than one with the standard suspension.
    Both of mine are lower than the standard car.
    MY09 Silver Leaf 118TSI DSG, & MY09 Candy White 103TDI DSG
  10. #40
    Nov 2009
    Rowville, Vic
    Smile
    Good! I thought so! Any pics of yrs?
    ~Nic~
