Results 11 to 20 of 28
Thread: Speedometer readings
    Aug 2009
    Melbourne, Vic
    Mines GPS 100 km/h=CanBus/ABS 100 = digital speedo 106 = analogue 106. So digital & Analogue match for me which is fortunate.
    Sep 2009
    Melbourne - Australia
    I'm planning to change the wheels of my car to 18" once it's deliver and I was wondering if the speedometer reading would change? How can this be adjusted on the VAGCOM
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by oileoi View Post
    Most probably not. Depends on the tyres you fit with the new wheels. Generally when you fit lower profile tyres to the larger wheels, the rolling diameter will stay much the same and no change to speedo. So specify tyres on your 18" wheels that match the circumference of your delivered tyres and it wont be an issue.
    It can be fiddled with, but not fixed with VAGCOM. But as mentioned you wont have an issue if you keep to your original rolling diameter.
    Sep 2009
    Logger, thanks for your answer the tires im planning to fit into my car are 225/40/R18 Y KUHMO 31 SPT.
    Do you reckon the speedo reading will change at all?
    Aug 2009
    Melbourne, Vic
    What sort of car are you getting and what sort of tyres will it come with?
    If for example you got a stock TSI118 it will come with 205/55/R16 and changing them to 225/40/R18 will alter your speedo by 0.8km at 100kmh which is trivial. Way less than the ~6% over read error that the car intentionally comes with. In fact this change should reduce the 6% over read to about 5% and is arguably an improvement.
    Once you know what tyres your are replacing, use a tyre size calculator and it will let you compare the two sizes.
    Nov 2009
    Melbourne. Victoria
    I've found the dead reckoning using the RNS510 is accurate
    analog = 109
    digital = 106
    rns510 dead reckoning = 100 kmph
    Oct 2009
    Melbourne, Victoria
    Another way of checking is sit on the freeway. Set your cruise control, reset your computer so the average speed resets. Keep a constant speed and there you will have the difference. The average speed will be the true speed.
    So as it goes for most 100 real is 106 / 107 displayed.
    Sep 2009
    Quote Originally Posted by logger View Post
    I'll be getting a 90 TSI but I'm not entirely sure about the specs of the tires that it comes with. I called Barloworld and the sales person couldn't tell me either. The only thing they told me was that it could come with Continental tires or Michellin but they didn't tell me the specs. That really didn't help me at all.
    I had a look at the specs PDF on the VW website and I couldn't find the specs for tires that comes with the (Wellington) 15 x 6½” Wheels either, I'm guessing they will be 195/65R15 tires.
    I used the tire calculator (thanks logger) and got the following results:
    Differences between Wheel/Tyre 1 ( 195/65R15 ) & 2 ( 225/40R18 )
    Rolling Radius 1.35mm
    Circumference 8.48mm
    Diameter 2.7mm
    When your speedo reads 100km/hr you're actually at 100.42 km/hr
    So basically minimal difference, however I will be using a 8.5 x 18" rims so my tires would be stretch a little but not much at all so I guess the speedo reading should be fairly accurate?
    Feb 2009
    Will 8.5s fit under the guards?? I didn't think they would without extensions...
    Sep 2009
    Quote Originally Posted by Swallowtail View Post
    Yes they will without any problems!
