Page 15 of 16 FirstFirst ... 513141516 LastLast
Results 141 to 150 of 156
Thread: Speedo Inaccurate
  1. #141
    Nov 2010
    Quote Originally Posted by Glennb View Post
    according to "authorities" here in VIC, going 5km/h over the limit will automatically cause you to spear off the road and into a tree....
    Not to mention every km/h that you are over, a kitteh meets its end
    Sent from my HTC Desire using Tapatalk
  2. #142
    Feb 2009
    Sydney, Australia
    Seriously?
    /me starts driving around at 50km/h over the speed limit everywhere...
  3. #143
    Erskineville, NSW
    Did the avg speed reset thing yesterday, which is kind-of annoying because it reset my avg fuel consumption & hours runs as well.....
    100kmh on the speedo = 97kmh on the GPS = 95kmh on the digital readout. So if the digital readout is accurate (I believe the GPS is more accurate) then there was a >10% (12%-13%) difference between analogue & digital speeds when the car was fresh from the factory. No wonder everyone in the fast lane was zooming past.
  4. #144
    my speedo shows 140km/h, but the GPS says 130km/h...kinda feel ripped off, but VW tells me with its within tolerance.
    I said to them will they refund me the 10,000kms worth of depreciation when my car hits 100,000km but has actually done abit over 90,000km....
    they had no answer...
  5. #145
    Erskineville, NSW
    Quote Originally Posted by juve23 View Post
    The speedo & odo are independant. I agree the odo still reads wrong but it isn't as bad as the speedo. You need to use one of those 5km long "Odometer check" strips that they have on motorways - the blue signs and use your tripmeter.
  6. #146
    Feb 2009
    Sydney, Australia
    brad, if your ODO is wrong, then that would be why your 'trip meter reset test' failed to get the same reading as a GPS.
    Your ODO shouldn't be wrong unless there is some variation in your wheels/tyres from stock.
    On my R, doing the 5km long check is perfectly accurate (within the errors of that check anyway), and the ODO matches the distance reported via a Tom Tom GPS, and the speed matches the trip meter average etc.
    So in your case, adjusting the base value in VCDS to get the ODO back into an accurate position would be beneficial to you. It won't help the speedo being out.
  7. #147
    Nov 2009
    Last time I watched ACA they said
    Stopped reading there hehe. They're as credible as the ranga running the country right now......
    lol what he said
  8. #148
    Canberra
    Just one question if possible. Is the MFD display of speed closer (not the average speed display) to accurate than the speedo?
  9. #149
    Feb 2009
    Sydney, Australia
    You tell us?
    It completely depends on your car...
  10. #150
    Jul 2010
    Gympie Queensland
    Cool
    Makes you wonder doesn't it? In my VW Jetta 1.6 TDI (as in most VW s I assume)
    There are 3 speeds. One the digital readout; two the old needle on the dial and three the one you get if you put your watch together with the odo.
    AND. They all disagree with each other AND they're all not correct.
    Maybe doing mental calculations of 107% of speed limit signs is a cunning way VW has to keep my mind constantly working and alert , thus keeping my travel experience a safer one???????
    Love my Volkswagen.
    Love my GPS. Happy motoring.
    rory
