Page 1 of 16 12311 ... LastLast
Results 1 to 10 of 156
Thread: Speedo Inaccurate
    Feb 2010
    Darwin
    Speedo Inaccurate
    Hi,
    Had our first long drive yesterday in my wife's new Golf VI. I fitted my GPS to check the speedo accuracy. It turns out the speedo is out by -7%, ie at an indicated 100km/h we are only traveling at 93km/h.
    Does anyone know if the VW service guys would be able to correct this?
    Cheers,
    Dave.
    Canberra
    Quote Originally Posted by Topend View Post
    Cheers,
    Dave.
    Welcome aboard Dave. Lots of useful info here.
    The short answer is "No". Some of the more switched on techs probably could, but I doubt that any of them would be willing to do it for you. This under-reading error is common on many modern cars due to ADR requirements.
    If you want lots more info try the search facility, as there have been many threads covering this issue and discussing what options are available.
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by gregozedobe View Post
    There is no good reason for this, the ADR says you CANT read under, but you can read over by up to 10% (7% in your case). If you run the numbers of all the standard wheel and tyre combo's there are available (and I have for the Mk5) there is about 1% difference in rolling diameter across the range. So even if you set the speed right for the largest wheel, it should only be out by 1% for the smallest.
    Add to this that tyre wear will only ever make you go slower (as the tyre wears it gets a smaller rolling diameter) and even then it's only about 4%.
    Why all the speedo's are so wrong is beyond me, especially when there are so many reports of people bringing up the speed on the digital readout and it's much closer to reality :S
    Feb 2010
    Darwin
    Thanks for the responses. I should add that my speedo and MFD don't read the same either. There is a 2 or 3 km/h difference.
    It is annoying that in order to travel at 100km/h the speedo has to indicate 108km/h and for 110km/h the speedo has to indicate 119km/h. We have 130km/h limits up here (use to be unlimited) so it will be interesting to see what the speedo indicates at that speed.
    Cheers,
    Dave.
    Golf 90tsi
    DSG
    Comfort Package
    Erskineville, NSW
    It will pretty much be 7% all the way through.
    On my Octavia, I have to do 120kmh to maintain a true 110kmh. It must be an endemic thing among the car manufacturers because I'm constantly having to flash cars on the M5 to get out of my way & they think I'm being aggro - all I want to do is get to work and stick to the speed limit.
    Dec 2008
    Perth
    Is the MFD more accurate than the analogue (speedo) display?
    MY14.5 VW Polo 81tsi Comfortline - Candy White - Comfort Pack
    Feb 2010
    Darwin
    Quote Originally Posted by Coaster View Post
    Yes, 2km/h closer to the true speed.
    Golf 90tsi
    DSG
    Comfort Package
    Feb 2010
    Darwin
    I tested at a true 130km/h this morning. The speedo indicates 141km/h.
    Golf 90tsi
    DSG
    Comfort Package
    Feb 2010
    Sydney,NSW
    Probably better for your licence that it over reads.
    If you were travelling to the nearest star in our galaxy that 8kph difference would probably count.
    Going down to the shops it probably won't.
    Jan 2010
    brisbane
    its to get you to think you are going from 0-100 in shorter time
