Results 1 to 10 of 18
Thread: Speedo Display in the MFD - software bug?
    Dec 2009
    Aspendale, Vic
    I test drove a MK6 GTI today. I went through the MFD options and found the one called alternative speedo display... I was actually specifically looking for it, as I much prefer a digital readout.
    Only problem though... it only shows in mph. Not km/hr. I checked the units and even the language (UK english), but nothing would change it.
    Same problem as shown in this thread for the R36...
    http://www.vwwatercooled.org.au/newf...ight=mfd+speed
    I asked the dealer and he said it could be done... insisted he show me, 10 mins later and it's still mph
    Does the mech dept at dealers have the ability to change this, or was that just dealer BS x2.
    Anyone know a workaround?
    Perth WA
    The "Alternative" in "Alternative Speed Display" means it will be the opposite of whatever your analogue speedo is, it's meant to be this way. It comes in handy for example in Europe where some countries use MPH and others use km/h.
    If you want a digital speed display in km/h you just need to scroll through with the up/down arrows on the steering wheel when on the normal display until it says "Speed 0km/h". Eg. when it's displaying average fuel consumption/oil temperature/time travelled/distance to empty/whatever scroll through and you will find the digital speed readout in km/h.
    Hope that helps. I would take a pic/video but I've got a Mk5 with the old menu system which doesn't have a digital speed display and my dad's Mk6 is parked at the airport.
    Edit: The picture in the thread you linked shows the alternate speed display where the temperature normally is (as it's supposed to be)... the normal digital display in km/h will come up where this picture shows "Range 300km"
    Quote Originally Posted by Pana in the other thread View Post
    | Tiguan 125TSI DSG |
    Sep 2009
    This vid will probably help:
    http://www.youtube.com/user/AskaVWsa.../4/mF6ApcWLPSo
    Was done in a US-spec Golf GTI but he demonstrates switching b/w miles per hour and kms per hour in the digital speed display.
    Feb 2010
    sydney
    MFD question
    i didnt seem to find the answer to this on the search function so i guess i might ask here.
    i got a golf 118 tsi and the mfd's alt speed display only has mph and not kph, is there a way to change it?
    like if i turn it off, the big display shows km/h but the alt speed display is gone and has temperature instead. so thanks to anyone that can help and a cookie too!
    Jan 2008
    Quote Originally Posted by Simz View Post
    Have you RTFM as I'm pretty sure it covers it in there.
    Feb 2009
    Sydney, Australia
    I merged your thread into here, as the answer is above (although I see Maverick just got in too, and he's also got the correct answer )
    Nov 2006
    Canberra, Australia
    If all else fails... (x) mph x 0.6 = km/h
    MY10 S3 3dr
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by Lima View Post
    *cough* other way around....
    mph x 1.61 = km/h
    (or 1.609344 if you have to be more precise)
    May 2010
    It's easy to change this. Of course, that would require remembering where in the MFD it is, but there's a setting for km/h or mph, including US or UK for consumption. It's something like the second or third last option on the main MFD menu to go into the choices.
    GTI | Carbon | Man | 5 door | Leather | 18" Detroit | Bluetooth | MDI | Bi-Xenon
    Nov 2009
    This one's a bit tricky from memory (and unfortunately, it's not properly documented in the manual - like many things related to the MFD).
    I've only found the option to disable the alternate speed and enable the separate MFD page for km/h. Setting the units to km/h (MDF settings -> Units?) doesn't change it. Maybe it's not possible - at least without Vag-Com?
    Last edited by AdamD; 18-06-2010 at 02:15 PM. Reason: Address the OP's question better
