Some questions about the MY12 GTI (aka - things I dislike about my GTI)
Had the car for 2 weeks and generally, I'm happy with it.
Questions about the MFD display.
1) The gear selector display seems pointless when it constantly tells you what gear it wants you to be in, rather than the gear you are in. Is there a way to change this?
2) The odometer display is replaced by a symbol that looks like a 'tacho' any time the car is in motion. Keeping in mind that I'm not using cruise control (which is the only symbol I can find in the manual that looks like it). Can anyone tell me what it means (or guide me to the page in the manual)?
3) The average fuel consumption (AFC) seems to reset itself everytime you start the car. Every other car I've driven, the AFC only resets if you do it manually. Again, this seems to be a pointless display. I mean who keeps track of what your fuel consumption is from drive to drive?! Anyway of changing it so that it is a static figure?
Questions in general
4) The other night it was raining so I couldn't open the windows. The windscreen completely fogged up. I tried all different A/C settings (high/low, cold/hot, blowing on the window/other directions) but nothing worked. Are there any secrets I should know about? I've never had this problem in other cars.
5) Is the GTI symbol on the back of the car glued on, or is it screwed in? I'd like to remove it. Can the symbol on the front grill be removed easily?
6) The clutch is so soft (I could probably press it with a finger). Is this normal?
- You may not post replies
- You may not edit your posts
Forum Rules
