Results 11 to 20 of 24
Thread: softening the suspension
    Feb 2009
    Sydney, Australia
    why was that thread locked?
    Oh yeah, that's good then
    Dec 2009
    Actually my apologies, it wasn't locked. http://www.vwwatercooled.org.au/newf...ad.php?t=39176
    So yes, you can get Goodyear F1's + VMR710's landed for about $2500 AUD all in.
    Add the $2000 USD ($2300-2500) for Bilstien PSS10 and you have a pretty damn good quality setup.
    You would be running on 19's, lowering the car to look shiz hot and having enough damper settings to find something comfortable.
    It'd look just like this. $5k is still a hell of a lot of money to spend .. but to each their own. Stage I first, then worry about this.
    2019 BMW M3 CS
    Feb 2009
    Sydney, Australia
    The thing is though, the rims in that picture are at least 20"
    This is the VW press shot for the Golf R with 19" Rims (the resolution is high enough that you can actually read that these are 235/35 tyres) and there is clearly much more profile on them than the picture you've posted
    http://www.ausmotive.com/images/VW-Golf-R-12.jpg
    The other thing about having the car that low is the tyres hitting the wheel arches when going over a bump during cornering... this would even happen in my MKV GTI on standard springs and 235/40R18 Oettinger wheels (with 50mm offset). You'd have to have the suspension MUCH tighter to avoid that issue if you lowered the car to that level.
    Dec 2009
    Those wheels are 19". I've read the thread where the owner of that car posted the pictures. I think the photo was played with in Photoshop.
    As i've said - I've gone through this process a few times before (with the TT and also an HSV Coupe), so I am not new to any of this by any means.
    The wheels wont rub with the correct offset/spacing and with a fully adjustable coil-over suspension, you can select the ride that suits accordingly.
    .. so that it wont rub.
    2019 BMW M3 CS
    Dec 2009
    Also, just because I would like the car to sit low, doesn't mean i'm talking about making it look ridiculous. It's all about performance + looks.. not just looks.
    I'd never set mine up as low as it seems to be in that picture, but low enough to close out most of the wheel gap from the fender.
    2019 BMW M3 CS
    Feb 2009
    Sydney, Australia
    Fair enough... it'd be nice to see that car without the photoshopping done, cause they certainly don't look like they're 19's - unless they changed the rolling circumference so that the tyres have a lower profile - in which case the speedo will be displaying much faster than he's actually travelling.
    Dec 2009
    For a comparison and example of how I would be setting up the GTI (or thereabouts), here's my TT.
    Running H&R Coilovers and Axis Hiro 19" wheels. Gotta love the 10" rear
    2019 BMW M3 CS
    Feb 2009
    Sydney, Australia
    Yeah - that looks much better than that black GTI from above
    Dec 2009
    See.. I no silly
    2019 BMW M3 CS
    Dec 2009
    Brighton, Victoria
    Your TT is beautiful.
    "I just want to make it that little bit better, and little bit more unique."
