Results 11 to 20 of 29
Thread: Smoke/Steam out of exhaust? Normal?
    Jan 2011
    Brisbane - QLD
    i also see some smoke from the exhaust during WOT... somehow prefer it to spit fire, popping and crackling instead.
    anyone know how to get the GTI to spit fire?
    A lot of the smoke under hard acceleration on turbo car is the fact that the ECU runs the engine rich at WOT.
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by nat225 View Post
    Remove your cat, and start going through the upgrade stages.
    Fab_R has said that people following him has said his car has shot flames outta his exhaust pipe - he has the full APR Golf R TBE with its motorsports cat...
    Jan 2011
    Brisbane - QLD
    Quote Originally Posted by Corey_R View Post
    I'm running on APR downpipe (100cell cat) and Akra cat back + Bluefin State 2... i may need to get a friend to follow behind me to check then..:p
    or stick a marsmallow at the back and see it it gets burnt..
    May 2010
    WA
    Quote Originally Posted by pologti18t View Post
    What is WOT? (Not trying to be funny... I just don't know).
    Golf VI GTI MY13 Candy white/ DSG/ Detroits/ tint/ reverse camera/ parking sensors
    2016 Skoda Octavia 162TSI RS Wagon (Silver/DSG/Tech pack/ Black pack)
    Jan 2011
    Brisbane - QLD
    wide open throttle... basically flooring your accelerator.
    Feb 2009
    Sydney, Australia
    hehe, yeah, the more PC version of WFO
    May 2010
    WA
    I think I can work that one out!
    Feb 2009
    Sydney, Australia
    Legendary New Jersey thrash-metalists Overkill have an album titled W.F.O. and it features a song called Fast Junkie. Whilst the MTV video lyrics don't feature the WFO term of the album version for obvious reasons, it's all about racing
    Nov 2009
    Precisely. I think this is what the OP is seeing.
    Guys, most engines are tuned conservatively from the factory. Under heavy loads at high revs, the ECU can mix additional fuel into the mixture to reduce the combustion temperatures inside the cylinders (more fuel in the mix = a cooler burn). This mixture may make the engine perform less well than a leaner mixture (a lower fuel/air ratio), but at least it can prevent detonation and piston/cylinder damage that may occur should the motor run too lean at high RPM or under high loads.
    So, the upshot is - give the car a good hard rev and it's not unusual to see a bit of black smoke/soot, or sometimes the appearance of vapour/steam from the exhaust (depending on the air and exhaust temps). If the car is blowing smoke or heavy vapour under normal operating conditions, however, you may have a problem.
