Page 8 of 8 FirstFirst ... 678
Results 71 to 80 of 80
Thread: Slow death of a 118TSI
  1. #71
    Oct 2014
    Quote Originally Posted by Rawcpoppa View Post
    Revised this year so take that for what it is worth. Last revision was in 2011!
    Attachment 12975
    Thanks for that!
    I decided to have a closer look at the engine and had a dry compression test, which showed 175, 175, 140, 155. I'm leaving it for a couple of weeks regular driving before doing it again to test for deterioration in cylinders 3 and 4. Also appears to be a bit of a leak on the turbo somewhere. I'm tossing up whether a switch out for a used 2012+ low km motor or go for the rebuild should the condition deteriorate. Any opinions on that?
    Also, I'm running APR stage 1 and have found the 95 RON and 98 RON maps to idle quite rough on cold startups. I've actually taken to switching to stock mode which is much smoother on cold and then switching over once warm.
  2. They do idle like crap when cold but that fixes itself fairly quickly
  3. #73
    Oct 2014
    Quote Originally Posted by Pilot View Post
    By rough idle I mean you can feel a slight shudder from the engine when you are stopped... Its just a slight vibration kind of that you can feel in the seat... and then it will misfire eventually
    Did that rough idle resolve completely with the coil pack replacement?
  4. It did when warm, but cold is still the same lol
  5. #75
    Oct 2014
    Yeah that lean run at the beginning is savage.
  6. #76
    Oct 2014
    Attachment 12975
    What is that site you got the screenshot from? Looks fantastic...
  7. #77
    Oct 2014
    Quote Originally Posted by volksMuller View Post
    piston code ends in a CK ,these are the latest revised version...as for a used engine ??????how good is it ????
    Well that's the big unknown I guess. I'm trying to find out as much as possible so that when the 2009 engine i'm running finally goes bang I can make the most informed choice. I've been quoted around $4,500 for a rebuild so far after a 175, 175, 140, 155 compression test got me thinking.
  8. #78
    Trinidad and Tobago
    Quote Originally Posted by Mk R View Post
    http://ifinterface.com/
    Click Welcome ----->Free Services------->CarProg2
    Alternatively you can use
    Volkswagen Teile Katalog (Pats Catalog)
  9. #79
    Oct 2014
    Had another dry compression test run the other day, 30 days after the last. Went from
    175; 175; 140; 155 to
    171; 175; 137; 151.
    Can see there is increased leakage across multiple cylinders now and getting ready for the eventual failure, guessing it'll happen within the next couple of months. Engine still pulls ok although there is more of a vibration at idle when warm despite replacing coil packs and plugs.
    Have been driving as per normal with the APR tune to see how it fared. I am wondering if the engine is replaced instead of rebuilt whether the APR programmed ECU can simply be switched over to the new CAVD engine. Anyone know if that's the case?
  10. #80
    Jul 2013
    This thread has scared me right off a 118 tsi
