Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 80
Thread: Slow death of a 118TSI
  1. #61
    Nov 2009
    SEQLD
    ^ correct me if im wrong, but i think "Pilots" car is a manual which seem to have a much better reliability rate than the DSG ones. Because the DSG always wants to be in the highest gear possible i believe they labour the engine and cause the engine to detonate (under load at low RPM) much more easily than the manuals.
    My brothers mk6 118tsi manual (which use to be my old car) started missing firing cylinder 4 really bad last Friday night just got diagnosed with low compression.
    Car has had all software updates alway run on 98ron and never laboured. Didn't show any signs and failing, still had good power.
    Lucky I sold it to him with extended warranty as the warranty got approved this afternoon and it's getting a full rebuild.
    Car has done 44k Kms.
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
  2. #62
    May 2010
    Bundanoon NSW
    So I hope after all your work, you really do get to enjoy your Golf.
    I enjoyed my 118TSI but became very concerned with all the reported problems.
    So when my son wanted a 'no interest' loan for new car.
    I gave him the Golf instead, and bought a Passat. I thought it would be even more comfortable
    Passat good car, but hard suspension not suited to bumpy country roads.
    MY13 Passat 130TDI Sedan. Autumn Brown Metalic, Desert Beige seats. Sat nav, Rev camera, Dynaudio, 12way adj seats. No ACC Previous Golf 118 TSI with ACC given to my son
  3. Quote Originally Posted by Cossor View Post
    Try Joms maxed out in a 118.... One would think you're being jumped on by a thousand leprechauns
  4. #64
    Quote Originally Posted by Rawcpoppa View Post
    Lucas do you know if anyone has stats for the 118? In terms of failure rates? If lean is really an issue there should be a continuous stream of complaint threads I gather.
    Here is some of the info i promised
    This is a MAP table from the stock tune, posted up by Mark from Recode in Sydney. He is on this forum as well as several others - he knows his tuning and knows VW's. Cant run much leaner than that: Parso's Golf R... - Page 191 (if you read the previous page he talks about how lean they run).
  5. #65
    Quote Originally Posted by Brendan_A View Post
    Sorry to hear mate - thankfully you have the warranty to fall back on and your brothers car will get a rebuilt engine.
    I bet piston no 4 has a hole in it (due to detonation). Piston no 4 seems to always be the one that goes bang.
  6. #66
    Trinidad and Tobago
    Thanks. This is good info.
  7. #67
    Trinidad and Tobago
    Lol maybe I should change my post to this is scary info!
  8. Quote Originally Posted by Rawcpoppa View Post
    Lol...
  9. #69
    Trinidad and Tobago
    Can anyone say what a faulty n80 valve does on these engines? Is it just for emissions or does it affect the car's performance?
  10. #70
    Jan 2012
    My n80 purge valve caused no driving issues except if you sat still with the car running and lightly pressed the throttle it would jump straight to 1400rpms and miss the ones in between, so no smooth acceleration. No engine light but got a soft code for incorrect flow. Clearing this code has fixed the issue for me.
    Ozzy
    2015 Golf R. Lapiz Blue.
