Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 80
Thread: Slow death of a 118TSI
  1. #51
    Trinidad and Tobago
    Pilot what symptoms did you have with the failing coilpack? Also what brand did you replace yours with?
  2. I cruise at 60 in 6th because it likes to... I do believe that the 7spd sits in 7th from 55km which strains the engine
  3. #53
    Quote Originally Posted by Rawcpoppa View Post
    I was thinking more along the lines of running lean if driven gingerly. Manual drivers don't use the highest gear when cruising like a DSG would?
    The 118's run very lean all the time from what i have seen - regardless of whether you are low RPM, high RPM or low throttle or heavy throttle.
    Some manual drivers will use the highest gear possible, but i will regularly drive at 60-65kph in 4th gear for example - the car is only doing about 2400rpm at this speed. I will only go into 6th gear if im doing 80kph or higher for a period of time.
  4. Quote Originally Posted by Rawcpoppa View Post
    Rough idle, eventually jerky when at WOT.... And then misfiring.... I put VW ones in as the R8 and 2.0L ones DONT fit... if only they did.... Can't find any good aftermarket ones
  5. #55
    Trinidad and Tobago
    I share your pain. Seems like I have a faulty one as well. Similar symptoms minus the rough idle. Ended up getting a coilpack made by beru. Hopefully it cures my issues.
    Lucas do you know if anyone has stats for the 118? In terms of failure rates? If lean is really an issue there should be a continuous stream of complaint threads I gather.
  6. Quote Originally Posted by Rawcpoppa View Post
    By rough idle I mean you can feel a slight shudder from the engine when you are stopped... Its just a slight vibration kind of that you can feel in the seat... and then it will misfire eventually
  7. #57
    Trinidad and Tobago
    I have gotten EPC light with VCDS showing misfire in cylinder 1. Epc clears if I switch off and switch back on the engine. It's pretty interesting doing that at highway speeds.
  8. I got an EPC fault when I started up about 8 hours before I got a misfire
  9. Mine also misfired in cylinder one
  10. #60
    Penty of info in the Polo 6R section and also scattered through the Mk6 section. Countless Polo guys have had engine rebuilds to due pistons having holes in them (due to detonation from running too lean).
    A local tuner (Recode) posted some info a few months ago about how lean they run (he was tuning one and took logs) and it was crazy lean. After i finish work, ill find some of the info and post back here.
