Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 80
Thread: Slow death of a 118TSI
  1. #21
    Feb 2013
    northern Perth WA
    I am SO glad we got rid of our 118TSI wagon, after new engines, clutches, wheel bearings etc, even if it cost us $30K to upgrade to a diesel Mk7 wagon!
  2. #22
    Jan 2012
    Epping, NSW
    Ouch, now the images have been fixed, that ran so lean! I had an old Datto in the 90s and cracked a couple of pistons, it was white like that...(running twin Webbers, compression ratio too high also).
    Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
  3. #23
    way way way out west, NSW
    quick update
    Quick update: Decided to give the rusty replacement engine an electolysis bath to try and remove the rust from the cylinder walls without scrubbing.
    The result was not what I wanted, but definitely surprising!!
    Slow death of a 118TSI-10616422_10152710941395871_3996806235066514833_n-jpg
    Slow death of a 118TSI-983790_10152711078985871_4410929311367029198_n-jpg
  4. #24
    Trinidad and Tobago
    Can one tell if an engine is running lean before any warning lights pop up???
    Also, how does the white residue imply running lean?
  5. #25
    Trinidad and Tobago
    Subscribed. Good luck!
    Can you link to where you read about the improvements VW has done to this engine over the years? I have a CAVD from 2012 and I always wonder how long it will last. Currently doing 72,000 km.
  6. #26
    Jul 2012
    Sinagra, Western Australia
    I have logged newer model twin charged vehicles and found them to run down well into the 11:1 a/f which should be nice & safe.
  7. #27
    Quote Originally Posted by Rawcpoppa View Post
    Get someone with a VCDS cable who knows how to use it and go log your lambda values on some full throttle runs.'or take the car to a dyno and get them to log your a/f ratios with the sniffer up the exhaust pipe. The dyno method isnt quite as accurace but will give you a reasonable idea.
    From memory the white residue is due to excessive nitrogen being produced due to the lean fuel mixture and excessive heat. Basically that white powder look is not good.
  8. #28
    Trinidad and Tobago
    Thanks. I have VCDS.
  9. Subd... I'm considering changing my sparks because they havnt been done in a while and I just hit 100000
  10. #30
    Erskineville, NSW
    Quote Originally Posted by Pilot View Post
    I think the recommended interval for that engine is 60,000km. At the most it will be 90,000km.
