Results 1 to 9 of 9
Thread: Sharp Brakes
    Jun 2014
    Planet Earth
    Sharp Brakes
    OK to cut a long story short I've recently purchased a MK6 Golf and overall I am very happy with my new car but the brakes are incredibly sharp...It's not really an issue when I am driving along at 40mph but in stop start traffic I find when I press down on the brake pedal I seem to get very little feedback then it suddenly grabs...I don't know if this is due to brake assist intervening or if brake technology has simply moved on since I last bought a car but I've owned quite a few German cars in the past including a MK4 Golf and a E46 318 and both of those cars were a lot gentler and more progressive...So back to the question...is this due to brake assist? If so is there any way I can either tone down the setting or disable it completely.
    Any advice would be greatly appreciated. Tia folks
    Nov 2009
    The Mk6 brakes are quite touchy and can take a little bit of getting used to, but they're still progressive and easy to modulate. What you're describing isn't brake assist either.
    I'd suggest you get your dealer or a mechanic check the brake setup - pads, disc widths and condition, fluid etc. Might need a service and some adjustment.
    Dec 2012
    Sutherland Shire, Sydney
    Brake assist only kicks in when you perform an emergency stop - sudden and very heavy brake application - it's very rare to engage
    (There is also hill assist where the brakes are held on when you remove your foot from the brake until you hit the gas)
    The overly sensitive brake pedal at low speeds takes time to get used to
    When you adjust to it, you will find stop start and round town driving less fatiguing as you use very little brake pressure
    Jul 2012
    Sinagra, Western Australia
    Brake assist isn't just for emergency situations. It also helps out old people :p
    Sent from my HTC_PN071 using Tapatalk
    Volks Handy
    Servicing - Repairs - Diagnostics - Mobile fault scanning/clearing - A/c work
    10 years experience working for Audi/VW/Skoda
    Now in Perth NOR, Western Australia.
    Dec 2009
    Kew, VIC
    It's normal for the Mk6 — has been toned down again on the Mk7.
    Might be due to their choice of pads combined with the usual over-soft Euro discs.
    I fond I got used to it after a while, but passengers always remarked on it.
    Dec 2012
    Quote Originally Posted by Snail Style View Post
    In what way?
    Quote Originally Posted by www.volkswagen.co.uk
    Hydraulic Brake Assist (HBA)
    Our hydraulic brake assist system (HBA) comes to your aid in emergency or panic braking situations. The brake assist realises from the speed at which you brake that you need full braking power. It automatically boosts the brake pressure up to the ABS control threshold for as long as you keep the brake pedal pressed down. If you then ease off the pedal, the system will reduce the brake pressure again to match the brake pedal's position. This safety function can substantially shorten your car's stopping distance, although it's so smooth in operation you'll hardly notice it working
    Nov 2009
    Quote Originally Posted by Martin View Post
    In what way?
    I believe that was sarcasm.
    Nov 2012
    Brisbane, Queensland
    My mk6 is 3 years old and I still find it touchy occasionally, especially if I've been driving another car for a while. They stop on a dime when it matters tho!
    Dec 2006
    Kilsyth, VIC
    When I first got our Van (T5GP) I though it was bloody touchy, although after a little while I had no issues moving between my Mk3 and the Van... then I got a Mk6! That's a whole new level of touchy! Again it took a little while, but you do get used to it (then every thing else feels really crappy )
