Brake assist only kicks in when you perform an emergency stop - sudden and very heavy brake application - it's very rare to engage
(There is also hill assist where the brakes are held on when you remove your foot from the brake until you hit the gas)
The overly sensitive brake pedal at low speeds takes time to get used to
When you adjust to it, you will find stop start and round town driving less fatiguing as you use very little brake pressure
