You certainly can save a lot of money doing the servicing your self and some tasks are not very hard
The thing is, you need to take it seriously, there are many checks that the workshop does as a matter of course
Are you really going to check the pad wear indicators every six months? It's important and easy to get caught out
You need to jack the car up and remove the wheel to do the inspection
Are you able to check the rotor thickness when you change the pads? Need a micrometer or a special vernier caliper
Are you able to remove the brake rotor and use another vehicle to take the rotor in for machining (costs ~$50 for a pair) when you change the brake pads?
Are you going to change the belts (alternator, power steering) at the prescribed intervals?
Are you able to scan the car for faults?
Some things like changing the coolant, power steering oil and the belts are a hassle to do
If it's a TFSI or TSI engine it's best to get the workshop to clean the inlet valves - it's a very messy job with a little risk
I do my own servicing for the Wife's Mazda3, my Skoda Octavia and my Nissan 350Z
It's a pain getting little parts/washers all the time
Easily steals half a day in the weekend - and that's only if everything goes ok!
Really easy to miss service intervals (especially on the wife's car)
I'm booking the Skoda in to have the inlet valves cleaned up - so I still use the workshop for some things
I recently did the brakes on the wife's Mazda3, jacked up, removed the wheel and groaned when I saw the shock was wet with oil and needed to be replaced (replacing the front shocks on FWD cars is not much fun)
