Not impressed with 15000km service by dealership.
Not a fan of going back to dealerships for servicing, but i thought it'd be nice to have the VW stamp at least once in the log book.
Anyway, after driving out of the service dept at Campbelltown, i pulled over just to have a quick check under the bonnet. To be honest, the oil on the dipstick didnt look as clean as i wouldve expected, but i put it down to my paranoia, so dismissed the thought.
After getting home and the car being parked for an hour or so, I noticed a small pool (about 7cm) of oil under the sump plug. Further inspection revealed that the sump plug was leaking so i tightened it a touch (It seemed tight enough), cleaned the surrounding area and went for a drive til the engine oil was hot again, returned home, looked underneath, leak was there again.
It was Saturday, so couldnt get it back til Monday morning, but over the weekend had a closer look under the bonnet, and suspected the oil filter hadnt been changed. The hose that runs over the top, has a spacer grommet that rests on the filter. This spacer had caused a dust/dirty mark on the filter as if it had been there for some time (the car was bought in sept 2011), i cant imagine this dust/dirty mark on a brand new filter. My assumption was that the oil i initially checked wasnt as clean, as it was mixed with what was left in the original filter (about 200ml at a guess), but like i said, no real proof, just lots of suspician.
On returning the car 1st thing Monday morning, i informed the tech behind the counter of the leak, and also mentioned that I suspected the filter had not been changed. He guarenteed me it had (as i knew he would). I also played the soft approach and said that its possible it was forgotten, an easy error to make, especially if you are busy !!
I waited an hour or so while they worked on the car (it was good they attended to it immediately!). Upon completion, they apologised, i drove out, and once again checked under the bonnet just down the street from the service dept., removing the dipstick revealed the oil was definately cleaner (wiped it on my fingers), the area around the sump plug was dry and not leaking, and the oil filter looked like a brand spanker. (either that or it was well cleaned)
I ummed & rrrrrd about writing this thread, but in the end its up to readers to make there minds up. Personally, i dont think i could go to a dealership again (Ive been bitten before) unless there's a waiting room with glass partioning the workshop, which i know some dealerships now have, but i'll most likely do my own, or go to one of the few VW specialists in Sydney or outer areas upon recommendation by someone.
Sold - CW Mk6 MY12 GTI 5 Door DSG, Sunroof, Leather, RNS510, MDI, Tints, Lakin plate holders, BT & RVC, projected 'GTI' door lights
Current - Lapiz blue mk7 Golf R DSG fully optioned.
