Results 1 to 3 of 3
Thread: Second-hand MK6 Golf - vehicle inspection noted oil on undercarriage - thoughts?
    May 2016
    There's a second-hand VW Golf Mk6 I'm looking at buying - mileage is around 45,000 kms, MY2010.
    We got an NRMA inspection report, and they noted some issues around oil. Under "X - Fix Immediately":
    Oil drops forming on underbody - degrease and wash to rectify source and severity.
    Under "E - Early Repairs":
    • Engine oil level low - rectify
    • Low glycol levels in coolant - flush and replace
    • High moisture levels in brake fluid - flush
    And under "M - Minor Items", there were things like:
    • Minor oil dampness around rocker cover - monitor
    • Engine bay soiled
    • Various suspension components showing wear consistent with vehicles age & mileage
    • Check tyre pressure/alignment - vehicle veering to the left
    • Road test limited due to very low engine oil, road test carried out in wet weather conditions/50zone results may vary
    • Some other items - mostly cosmetic - I've omitted listing them all
    So I guess, is this oil thing something I should be worried about, and steer away? Or something I could potentially look into fixing?
    There was also something random about blue spray on driver side door rubber - no idea why, since the car is red. What is everybody's thoughts?
    Cheers,
    Victor
    Jul 2011
    AU
    What's the log book service history like?
    Erskineville, NSW
    The engine oil is low. It needs topping up and monitoring. TSIs can be oil burners, so maybe ask the owner how often they need to top-up?
    looking at the other stuff - it implies the servicing may not be up to scratch.
    When was the last service done?
    When was the brake fluid last flushed - if it was more than 2 years back then I'd think they've skimped on other things.
    Glycol is "lifetime" fill (5yrs/120,000km IIRC) - so it's due in terms of age.
    These engines get minor leaks from the cam position sensor and the VVT actuator. Both are easy fixes (<1hr each).
    If the rest of the vehicle seems OK then I can't see any reason to walk away but if it seems suss there are plenty of other GTIs out there.
    Personally, I find NRMA inspections fairly useless. State Roads do a better job.
