What software update are you running?
I suggest you have a look at Mavericks mygti.com site and look up the RNS510 updates
Hi There!
Has anyone got an SDHC card to read in the RNS-510?
My Oct 09 owner's manual says it supports SD cards up to 2 GB and SDHC cards up to 32GB. SD cards work fine but the 8GB Lexar SDHC card I've purchased won't read. Have tried reformatting a couple of time (in FAT32). I want to know if it the brand of card I'm using or if its something wrong with the reader.
John
2018 Skoda Superb TDI
2010 Skoda Superb TDI
2009 Golf VI 118 TSI
2006 Multivan TDI SOLD
I am using an 8GB Kingston SDHC in my RCD510, my car delivered Jan 10. Just make sure you can read and write in a PC or Notebook or the like. Some driver updates may be needed for PCs and Notebooks. It will need to have data on it for the in car RCD510 or similar RNS510 to initialize. As mentioned there may be updates for the unit also.
2017 MY18 Golf R Wolfsburg | Oryx White | DSG / 2021 MY21 T-Cross Style | S+V Package | Limestone Grey
Hi Rosslm
My car was delivered 12 Jan so I guess it would be the same as your's.
I can read (and play the tracks) from my 8GB SDHC card on my laptop and desk pc but not from the RNS510. Do you know what software version you have?
John
My Dad is due to pick up his MK6 next week.
The dealer has told him (after searching his VIN number) that he has V2 or the software which has a 'known corruption' and the dealership would be reverting him back to V1 software pre delivery
He said that V3 is not quite ready but when it comes available the dealership would recall the car for the upgrade
I believe the version of the software has something to do with the size of cards it can read?
Check if you need to have the SDHC card formatted any particular way (NTFS, FAT32, FAT16, etc).
Hi Glennb
I know that formating in NTFS doesn't work - It has to be FAT32.
I tried checking the version of my RNS510 this morning by turning the unit on (with out inserting the ignition key) and holding the setup button for 15 seconds. After about 5 seconds a Radio Setup menu appears - but I cannot get to the screen that displays the serial number and software version. Any tips?
John
I am not sure how to check the version, but I can tell you SDHC 32GB also works fine. I will try and get the software version tomorrow. Windows XP shows the file system as FAT32. I did not have to format the SDHC it worked out of the box. I am testing sound quality MP3 at 320Kbp approximately 100MB per CD and using WMA Lossless 220MB per CD, thats about 150 to 300 CDs on a chip the size of a 10 cent coin.
Hi Rosslm
Thanks for the info!
I converted my itunes library to mpeg to use in the RNS510. The bit rate itunes chose for the conversion was 160 kbps. I must say, with a good sound system and a quiet cabin, the compression is noticeable. Once I get this card problem ironed out I will go back to my original CDs and resample them directly to mpeg at a higher bitrate. I would be interested to read your conclusions on bit rate vs quality.
Off topic, but:
You don't necessarily need to convert them at a 'higher' bitrate. Just convert them using the recommended settings and LAME compile from Hydrogen Audio (after extracting them using a quality extraction program and from the original CDs of course).
Currently this would mean LAME v3.98.2 build from Rarewaves, and for a car (even with Dynaudio) or portable system (even with aftermarket IEMs), the -V2 option would be optimal. It 'aims for' 192kbps variable bit rate, but will range from an average of ~160 to 230 depending on the complexity of the content that you're encoding.
Hope that helps
