Results 1 to 10 of 15
Thread: scratches on b pillar~!
    sydney
    hi guys
    after only 2 weeks of owning my new car, some idiot has scratched the b pillar on my new car....
    its not too deep but its kinda long... does anyone know of any possible fixes?? can i use meguairs scratch x on this material??... although it prol wont work
    thanks
    croydon nth, vic
    do you mean the black trims on the door frames... they would be fairly cheap to replace if thats the case. from memory golf v trims were around $25ish
    hope that helps
    sydney
    yeh its the black shiny frames...
    realli? are they that cheap?!
    Feb 2009
    Sydney, Australia
    Yeah - they're not expensive.
    I'd be worried about using something abrasive on them like scratch x. Because its plastic and not a painted surface, the sratch x might just make the surface look dull and worn instead of original and shiney.
    Feb 2010
    Camden NSW
    Yep, I had the same thing happen to my new tiguan. When I picked it up from the dealers it was scratched lengthways on all trims. I had the weathershields fitted, and it seems that when they cleaned it before applying the shields, they used something too abrasive.
    Must be so careful what is used on these trims.
    Also watch out for passengers (or yourself) with rings on the fingers. Will cause deep scratches tooo if not careful.
    2018 Ralyee Green RS wagon. Fully optioned.
    Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
    2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
    Feb 2009
    The b-pillars are quite prone to scratching.
    I'd try a plastic polish..
    May 2010
    yup...mine are pretty much entirely covered in scratches
    Scirocco R - Candy White / DSG / Panoramic Roof / RNS510
    Mods - HPA ECU & DSG Stage 2 / VWR Racing Intake / Akrapovic Slip-On Titanium Tips / Milltek DP / HPA Mounts / Superpro LCA / H&R Sport Springs / VMR V710 19x8.5 / Michelin PSS 255-35
    May 2010
    Bundanoon NSW
    When restoring old radios (Plastic or bakelite) I use Brasso!. Follow this with car polish that has hard wax.
    Then finally, lots of buffing, elbow grease etc. (Only applies to shallow scratches)
    (But in most cases I use buffing wheel with various wax based polishing compounds)
    MY13 Passat 130TDI Sedan. Autumn Brown Metalic, Desert Beige seats. Sat nav, Rev camera, Dynaudio, 12way adj seats. No ACC Previous Golf 118 TSI with ACC given to my son
    Mar 2010
    Perth, WA
    When I got my car the b pillars were already scratched so I got a set of the carbon fibre pillar covers, they've been on now for about 3 months and still look excellent.
    No scratches on them at all. Can send pictures to you via PM as unable to post pics for some reason.
    Jan 2010
    State of Denial
    I used a Maguires swirl and scratch remover car polish on mine which got out some light scratches.
