Results 1 to 9 of 9
Thread: rns510 and sd card
    Nov 2006
    rns510 and sd card
    hey guys just bought an sd card for my gti. its a 16 gb sdhc formatted to fat 32. when i insert it into the card slot it says card error check sd card.
    Since then i have tried the card in two computers and it works fine. i also tried another card in the radio unit and the same error comes up.
    Anyone know whats going on
    Nov 2009
    NSW
    If you have a RNS 510, I dont think you can get 16GB SDHC working without firmware update. If it is a RCD 510, it should support up to 32 GB SDHC with FAT 32 formatting
    Nov 2006
    how do i get the firmware update. the car is only one month old do they have updates for them yet?
    Nov 2009
    NSW
    Quote Originally Posted by GeorgeM View Post
    http://www.my-gti.com/1198
    Here is a link! This is something I have found in a forum. To be honest, I have not tried it yet.
    Nov 2006
    to be honest im a bit hesitant to try that. I also tried an 8 gb sdhc card and got the same result. could the head unit be faulty
    Dec 2009
    Kew, VIC
    No, there should be nothing wrong.
    Without the latest update (which I'm also hesitant to try) it will only support up to 2GB card.
    Mind you, a 2GB card will hold a lot of music in MP3 format.
    Nov 2009
    NSW
    The RNS 510 unit only supports 2GB SD card with its normal firmware. There is nothing wrong in your unit
    Aug 2009
    NSW
    format it in NTFS
    Dec 2009
    Kew, VIC
    Quote Originally Posted by nuganen View Post
    format it in NTFS
    Which it won't look at (at least, mine won't — but then I did format it under Windows 7...)
    FAT and FAT32 are fine.
