Results 1 to 10 of 11
Thread: Reverse light housing leak
    Aug 2013
    Hi Folks,
    Just so people are aware - and hopefully it doesn't happen to anyone else - that my Golf's reverse light housing wasn't properly sealed from factory and water and moisture leaked inside.
    This caused the connection to oxidise (as observed the connections turned white rather than the steel colour), and when I closed the boot, on occasion the reverse light warning would appear on the display when I next started the car and the reverse light wouldn't work (curiously the brake light would).
    Took the car for a check-up at Barloworld Mascot. Their mechanic spotted it and they repaired it under warranty.
    I hope I'm the only one...
    Apr 2011
    I don't own a Mk6, but was the leak on the car or hatch portion of the reversing light cluster? The factory person may have moved to the Mk7 line, since I also had it happen on the hatch portion, but only once so far. (After washing the car)
    Mar 2013
    Brisbane QLD
    golf reverse are on the hatch...inner lamps...golf 5 used to leak on the outer lamps...VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Aug 2013
    Quote Originally Posted by vdubmotorworx View Post
    Quote Originally Posted by Eaglehawk View Post
    It's on the hatch...
    Another interesting note, the reverse light only works on the left hand side. But the right hand side, there's a light bulb fitted too and that's not used (in Oz). So if your reverse light blows, just swap with the right one until you can get to your local auto spare parts shop. The light bulb is around the $5 mark.
    Mar 2013
    Brisbane QLD
    the other side is your rear fog light...pull out your headlamp switch to turn on!
    Classic
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
    Aug 2013
    D'oh! How silly of me
    Aug 2013
    Quote Originally Posted by sVWatt View Post
    Classic
    Exactly how I feel atm ...
    I guess you live and learn!
    Jan 2010
    Condell Park, NSW
    And a damn fine thing it is too... Won't have a car without one after having been rear-ended twice in fog..
    VW Tiguan 110TSI Life | Tungsten Silver
    Quote Originally Posted by jbcool View Post
    Yup - I did on another forum topic. Your in good company
