I've installed my own OEM unit (and a few for other people over the years). It was 2011/12 but I did the RNS510 + OEM flippy badge in my Golf. If you’re keen
This was my install in my Cab, it’s much the same except you can run the cabling through the roof lining when you have one!
Success! RVC install into MK6 Cab
It’s not a bad job to tackle yourself if you’re confident enough in removing trim pieces and playing with wiring.
The alternative most go for these days is the RCD330+, an OEM unit with CarPlay and Android Auto support (just make sure you get the right model for one/both of those).
Replacing RNS 510 with RCD 330+
I’ve also installed Pioneer units, just remember that anything not OEM will require some soldering to get the different plug in there. Our Multivan is running a AVH-Z3100-DAB which also works very well.
When it comes to the camera itself, you need to do a little research to work out which one will be appropriate for you. The flip out badge is very neat, but you need either a converter (from 4 pin to RCA) or an after market version with a composite connection out of the box. Alternatively there are number plate light mounting units, again make sure you get the right connection(s).
