Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Retrofitting Front Fog Lamps
    Nov 2010
    Is it possible to purchase and have after market front fog lamps fitted to the Mk6 golf (118 TSI)?
    I chose not to have these built into the car but am now regretting this.
    If so, does anyone know of a reputable seller and installer of aftermarket kit?
    You probably want to let people know what kind of Golf you have...
    May 2010
    Bundanoon NSW
    Took my car into dealer for 1500 free service yesterday (They even washed it!)
    While there, asked about retrofit fog lights.
    In my case, Y11 build, fog lights as factory fitting only available with sport pack.
    re retrofit advised NO NO as causing big problems. Only reliable way is to install entirely seperate wiring loom, fuse, relay, and switch.
    EG, do not attempt to integrate into VW system
    Darn it, as big fogs where I live, and there are WOMBATS out there at night!
    MY13 Passat 130TDI Sedan. Autumn Brown Metalic, Desert Beige seats. Sat nav, Rev camera, Dynaudio, 12way adj seats. No ACC Previous Golf 118 TSI with ACC given to my son
    Nov 2009
    Cook, ACT
    Quote Originally Posted by Cossor View Post
    Not exactly the same as fog lights/lenses but Osram 65w Rallye globe made an appreciable improvement to our Tiguans night driving w/out fitting additional lights (regretfully didn't spec fogs), Candlepower in the US, $23 ea (fitted 4) $15 post. Might be some legal issue if ever identified (have to be pretty keen inspections unlike retro-fit xenons)??? Same-ish bulb life as OEM globes, no 'try hard' light diminishing, (sp edit) glare inducing blue tint either. Have a look into the Tiguan forums for more about fog lights. There seem to be options out there using OEM partsfor $3-400. Also if I recall a VW OEM replacement rotary/pull out switch. Probably the same aftermarket landscape for Golfs as Tiguans.
    Jul 2010
    Robina Gold Coast
    Quote Originally Posted by Daddo View Post
    They have the Mark6 fog light on ebay including the surrounds for $115 plus postage
    VW GOLF 6 MK6 2008- FOG LIGHTS LAMPS GRILLE SET NEW (eBay item 180586138509 end time 11-Dec-10 21:07:04 AEDST) : Cars, Bikes, Boats
    Volkswagen Golf VI 2.5 > Lighting > Fogs > ES#1876872 Fog Light Conversion Kit - 1K0998021
    These look to be a good option as well. I'm undecided as to whether the front fogs look good or bad, something about them doesn't fit with the rest of the car. The GTI on the other hand the fogs fit in with the whole look perfectly.
    Jul 2010
    Robina Gold Coast
    Quote Originally Posted by Syd118TSI View Post
    Either way if you do install you have to change the headlight switch to incorporate the fog lights .
    Feb 2010
    Quote Originally Posted by ian View Post
    not 100% true,
    I had just a button for it under the staring wheel
    probly not the best solution but it cost me $7
    His: Golf6 5door GTI DSG Carbon Sunroof MDI and 18" Drag rims + sticker that gives extra horse power
    Hers: Skoda Kodiaq Tech/Lux pack and sunroof
    Yeah that's mentioned I the link I provided. The switch is an additional $80 or so I think.
    Sep 2010
    Brisbane, Queensand
    118TSI Fog/Cornering lamps
    Has anyone done an install of the fog/cornering lamps at all?
    2010 Mk6 Golf 118TSI | Candy White | DSG | MDI |Votex Rear Wing | GTI Skirts | Fähren Customs
