Page 10 of 24 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 232
Thread: Retrofit of RVC to MK6 Golf
  1. #91
    Dec 2009
    Kew, VIC
    Thanks for the pointer, Adam.
    I popped the plastic pin out — which he'd done before making the video —(do use the right tool here (wide right-angle trim tool with V cut) — a screwdriver would be almost guaranteed to break it) then found I had just enough strength to force the corner of the carpet out sufficiently to wangle tools in. It almost beat me, tho', I can't apply the pressure that I could have done a score or so years ago, and it's not a place where I'd care to apply leverage without knowing what's under it.
    The right-hand side is further complicated by having the frame for the little cubby hole glued to it — which makes it still more rigid.
    This is definitely something that ought to have been better designed (perhaps it's yet another area organised for dealer income?)
    In any case, DIY bulb changers should ignore this item in the official sequence, unclip the relevant end of the lip trim, take the pin out and then proceed with caution.
    Thanks again for the tip.
  2. #92
    Nov 2009
    Quote Originally Posted by Idle View Post
    I agree, it can be mighty tricky. Several times I felt sure I was going to damage something, and it was really only blind faith in the manual, plus having seen Golfitup's video, that convinced me to keep at it. I've since pulled the carpet out a second time, and have noticed it's become much more pliable after the first battle.
    Glad to hear you've managed it!
  3. #93
    Finally got my replacement VAG-COM cable today (first one was a dud)... et, voila:
    By the way, to the OP, it IS possible to have both the RVC and OPS working at the same time, it just requires an extra bit of VCDS coding. You can see it shows an image of the car on the left of the screen above which is just a smaller version of the silhouette you normally see on the OPS screen.
  4. #94
    Apr 2010
    I was wondering how you were going with this the other day. I hope you get a chance to write up some instructions with photos to sway me to have a go as well
    Did you already have OPS or did you add them as well?
  5. #95
    Jul 2010
    damn, can't wait to get mine done... i'm just being so slack... how did you run the coaxial cable from the back of the unit to the fuse box ?
    over or under the steering wheel column, and do you need to remove the under steering wheel column dash parts?
  6. #96
    I'll write it up soon as my hosting provider restores my website (it'll be a bit too big to post in forum...form).
    And yeah, it's an R, so had OPS as standard.
    Quote Originally Posted by rs73 View Post
    Over the steering wheel, the dials/MFD had to come out but once out, you can get pretty easy access to everything down there
  7. #97
    Apr 2010
    I've run a Blutooth microphone cable under the steering column before - with the radio out it's as easy as pie.
    You could use Google Docs or Google Sites or any other free provider if need be to host the write-up.
    I didn't realise you had the Golf R - I know I wouldn't be in a hurry to pull apart my car if I had spent that much on it xD
  8. #98
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by Pepe View Post
    It would be great that if at all possible, you could write it up on the forums. Feel free to create multiple posts in a row to include all the information and images you need (and I'll delete anyone who posts in between if needed).
    The reason I say this, is that we just lose so much information to personal websites which go down etc.
  9. #99
    Dec 2009
    Kew, VIC
    Being pretty ham-fisted these days, (my hands shake too much for precise work) I looked for a way to avoid dismantling the instrument panel and found I could get the coax cable through quite easily without taking the dash apart or removing the fusebox — if you insert a suitable guide through the larger of the two round holes in the aluminium support behind the fusebox, it will pass neatly through the loops formed by the instrument panel loom and appear in the centre area. You then use it to pull the coax and 12V wire through behind the dash.
    If you want to be sure it's not fouling anything, it's easy to take a flash photo from the rear of the radio recess — hold the camera as far back as you can and angle it slightly toward you.
    I used a belt & braces method and also fed the section behind the dash through a short length of clear food grade polyester tube — 9mm ID IIRC — which is easily anchored at each end (get it very cheap at Clark Rubber,) supports the coax and ought to remove any possibility of its rubbing where it shouldn't.
    Running the coax to the rear, about the worst snag was that the sound damping material behind the upper side trim at the rear had been installed slightly too far back and was blocking the aperture the rear washer hose (and, perforce, the coax) comes up through — this stuff is really tough to get out of the way and it's 3 layers of metal down so very hard to reach. Eventually had to lever the upper trim away, insert a thin metal strip and blindly apply brute force — fortunately didn't damage anything and in the end managed to hold the stuff clear enough to get a probe down from the top.
    Haven't finished the install yet as I can't get some of the connector wires ( the ones with number ending in 129 — no stock in Australia, I'm told, and no apparent interest in getting any...) so the car's running around with no lower hatch trim.
    Have emailed Jon @ ECS Tuning (from whom I bought the camera unit and coax) re supply but no reply as yet.
    Not the end of the world as I got the two really essential ones (for the 4-pin plug on the latch connector, which is pretty much indispensable) and can cut the connector off the camera wires and sweat up a loom for the remainder if I must.
  10. #100
    I have a spare 129, 3 131s and a 133. Send me a PM and I'm sure we can sort something out.
