Page 18 of 24 FirstFirst ... 81617181920 ... LastLast
Results 171 to 180 of 232
Thread: Retrofit of RVC to MK6 Golf
  1. #171
    Dec 2009
    Kew, VIC
    Quote Originally Posted by Rays_R View Post
    Might be slightly off topic or answered previously but did a quick search with no results. Is there anyway to get the steering indicator lines on the RVC display similar to the Passat in a Golf?
    Only if you could fit the Passat setup, which wouldn't be easy, if possible at all. It has a separate controller, the Golf unit is all contained in the badge/latch assembly and not linked to the steering.
  2. #172
    Jul 2011
    Is there any easy way to find out if my RCD510 has a video input without removing the head unit?
    MY12 MKVI Golf GTI DSG
    MY16 MKVII Golf 92TSI Tendline DSG
  3. #173
    Nov 2009
    Quote Originally Posted by heyimsu View Post
    Not as far as I know of. But AFAIK all RCD-510s being made these days do have the video input, even if not specced with the RVC from the factory. Seems to have been that way since around MY11.
  4. #174
    Dec 2006
    Kilsyth, VIC
    I'm thinking about doing this to the new cab since the back end leave a little to be desired in the field of vision department...
    Have to keep digging to see where the wiring can actually run in this car since I don't have a roof cavity to play with
  5. #175
    Apr 2010
    Cool - be sure to let us know and take pics of any differences in procedure with the cab
  6. #176
    Jul 2011
    Seems like ECS tuning have released at RVC kit with all the wiring for $560 delivered. Looks like a pretty good deal imo. Not sure about the MK6s but the instructions for the MK5 involve cutting off some metal and a wiper blade mount to install this. Coding looks simple enough.
    Home Page > ES#1905735 Reverse Camera Kit - 1K0998025
    http://www.ecstuning.com/stage/edoc/...eraInstall.pdf
  7. #177
    Apr 2010
    Am I correct in thinking that this kit is somewhat more plug'n'play than previous jobs? Might be just what I need, perfect timing for taking weeks off work.
  8. #178
    Sydney Northern Beaches
    There is no cutting or removal of the wiper assembly for a Mk6 installation. However the coding is a little more complex.
    See my DIY here
    DIY Rear View Camera (RVC) installation on Golf "R"..
    The Car: MY20 Black Golf R Final Edition, 5 Door, Driver assistance package, Sun Roof.
  9. #179
    Apr 2010
    Yeah I've got your guide saved at home as well for 'just-in-case', but the ECS kit looks a tiny bit easier (don't have to build a loom)
    ---------- Post added 06-12-2011 at 01:39 PM ---------- Previous post was 02-12-2011 at 11:42 AM ----------
    I think I might take the plunge and order the ECS kit and use a combination of their guide and ozmale's. Hopefully the weather will be good (not too hot or raining) when I get around to fitting it.
  10. #180
    Agreed on this - the ECS kit looks great, will be ordering one of these close to christmas - Happy days!
