Ah...that would be great. Thanks in advance
That means you missed a setting in VCDS... that's what I did first too. There is another setting that defaults to the RVC view on the RNS with the OPS as an overlay on the left of the screen so you don't have to press the button each time. I've got it written down somewhere, will dig it out and post it.
Hey jumpman, what kind of garage did you bring your R to? A VW's or a typical car audio garage? I'm about to purchase a set from the ebay guy you mentioned. Also, did you get the 5K0 827 469 AQ or 5K0 827 469 Q? Thanks!
Chino
My garage is actually a VW specialist and the local MTM distributor. I think a garage with good knowledge of VW (especially when you have to pull off so much trim) and access to VCDS is key. I purchased the AQ version with the harness.
Just to follow up, Pepe or anyone have the settings for the VCDS to default to the camera with the OPS on the side?
Can't seem to find the USB stick I took all my notes on... it'll be around somewhere, otherwise, I'll go plug in the cable tomorrow night and find the setting for ya.
Idle, great list and info so far. I'm interested, but don't really understand the complexity. Can you explain how long this took in hours?? Degree of difficulty?
Any chance of you being able to share what you did write up (I figure whatever you have is better than knowing nothing).
I am down the road in Glen Iris, so a coaching session in melbourne would be another way to do it
FYI - current ECS price list for the bits is $586.41 including $63 shipping (All $US)
( I put an RNS-510 in and VW coded it in; they accidentally enabled the RVC view [which just gives a blank screen of course] so it is tempting me every time I go into reverse)
Golf VII GTI MY 14 (Post my VI Adidas GTI being written off)
I did actually get it pretty much complete — if you PM me your email I'll send it to you.
Time-wise, I didn't keep count (had problems with supply of bits etc., so it was spread over weeks) but doing it again would probably take me about four hours (knowing where to hit and what with helps a lot.)
20 years ago I'd have done it much quicker than that.
The biggest pain with this is running the cable from one end of the car to the other, means a lot of fiddling with trim, etc. As you have an Adidas, the guides won't apply fully either as you have R style LED tail lights, so that means you have to po out a tail light too (or solder it in place).
Idle's right though, it'd be much quicker if you've done it before (or can get someone to come help that has)
With all of the passionate talk from RVC owners / non-owners recently, I thought I'd ask a question around retro-fitting the RVC option to a Golf R. As mine was a "grab a car in stock with as close to the features as I can get" car, I didn't end up with the RVC which I possibly would have optioned (then again I probably wouldn't have chosen some of the optins I did get and now love).
Anyway, can a VW dealer retro fit this as an option and if so, do you know what they would charge? Or is it purely an option that you need to purchasse the parts for and either fit yourself or get a non-dealer garage to fit?
If Pepe fancies doing a job-lot of installs in Melbourne I'd put my order in for one - $50 an hour is it Pepe? Ha Ha.
MY11.5 Golf R - Candy White 5 door - still giggling like a child when I drive it!
