Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 57
Thread: Resale value - DSG or Manual??
  1. #21
    Sep 2009
    Perth, WA
    Driving my DSG GTI today, there were a couple of times I wished for a manual box. I'm yet to research it, but the DSG didn't behave as I'd expected. Firstly, when in manual shift mode, the DSG is excellent for holding gears during spirited acceleration and allowing high-rev downshifts. That is not a problem at all. The problem I encountered is when planting the accelerator when in a higher gear than optimal for maximum acceleration. For example, I was taking a sweeping bend at about 70kmh in 3rd gear - I planted the foot mid-corner thinking it would just feed the power smoothly. Instead, the box downshifted me to second with a jolt, pushed me to 6500rpm and forced me to shift up almost immediately - into the gear I'd previously selected. I tested this again in a straight line on the freeway - in 6th at 100kph, mashed the pedal to the floor in manual shift mode and the box dropped me down to 3rd to maximise acceleration. This is not what I expect. Do it in auto or sports mode, fine, but not when I select manual shift. If I feed the power more gently, it won't drop down, but it shouldn't matter. There is no reason for it to do this - it's not protecting the gearbox or my safety so it should leave the gear as is.
    Anyone know if an ECU flash changes this behaviour?
    If
  2. #22
    Sep 2007
    I'm glad you cleared up the post about not slamming the OP mav.
    ACC is some sort of electronic dampening system isn't it? For the kind of money, if you plan on getting the chip tuned, i would personally also consider aftermarket suspension. A middle range adjustable coilover set up would be of similar pricing, have the same sort of adjustability, albeit manual, but IMHO, be much more tune-able.
    I'm wondering if VW made any major revisions to the mk6 wet-clutch dsg from the mk5...
    our mk6 has the 7speed dry clutch and smooth driving would seem to just take time to finesse.
    87' MK2 GTI
    13' MK7 TDI
  3. #23
    Nov 2007
    Perth
    Quote Originally Posted by MurphyTheElf View Post
    a dsg tune might, but not an engine tune.
    A dsg tune removes the kick down and (I believe) the auto shift at redline.
    Sounds to me like you are hitting the kick down switch at the bottom of the accellerator travel, and although it is 'not an auto' those characterisics of an auto still apply.
    in the situations you described (manual mode) I'd have geared down with he paddles and not pushed it all the way to the floor, where it will behave like a normal auto box.
  4. #24
    Jan 2008
    ECU flash has nothing to do with the DSG and I'd steer clear of reflashing the DSG (many reasons).
    What Tinto said is correct, you're pressing down on the kickdown switch, you can still get maximum acceleration without pushing it to the floor. I think the manual has a diagram explaining this in more detail.
    You can also use the paddles to hold gears.
  5. #25
    Nov 2009
    Quote Originally Posted by Mk6 GTI View Post
    I Have ordered my GTI with ACC..Its one of the main features that differentiates this car from the mk5. It has been given very positive feedback. Just get the DSG and the ACC! hehe
    I was driving a new TDI with the ACC option the other day and really couldn't find a difference between any of the settings. Might have been a bit hard though as the diesel torque steers like hell under any kind of spirited driving. I'd def go DSG over ACC but again its all personal pref.
  6. #26
    ACC didn't get an overall glowing review in MOtors PCOTY testing. The issue they had was it altered the suspension, steering feel and throttle sensitivity all at once. The throttle in sports mode became too sensitive.
  7. #27
    Feb 2009
    ACC Seems like a bit of a gimmic to me, much like 4ws on the preludes. Another thing to go wrong when the car is out of warranty. Without driving one, it's hard to say if it would be better or as sporty as aftermarket suspension.
  8. #28
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by Maverick View Post
    I don't recall a diagram in the manual (which I did read from cover to cover) but that was a year ago and I don't have the manual anymore to check.
    Can you explain how you use the paddles to hold gears if you're in manual mode ?
  9. #29
    Nov 2009
    I have heard mixed reviews regarding the optional chassis control - some say its not worth it, some say its a great feature - So not sure whether its worth $1,500..
    I need tint, and blue tooth so I might scrap the ACC and negotiate a tint, bluetooth and DSG arrangement....... im kinda over manual cars
  10. #30
    Feb 2009
    Quote Originally Posted by lawsy82 View Post
    I agree, there probably aren't enough reviews around yet to say whether the ACC is worth it or not, but nothing really wrong with the current GTI's that don't have it. Better putting that toward the other options you want IMO.
    You could always get a manual car next time when you're over auto's .
