Results 1 to 7 of 7
Thread: Replacement Screws and Bolts
    Mar 2015
    Hey guys,
    So I have this torx bolt that has been stripped in my TSI. Is there anywhere to get a replacement for it? Please see pictures attached. I've looked up methods on how to remove it (i.e. cut into it so a flat head screw driver can fit), but if you guys have any other suggestions I am more than happy to see it.
    Thanks.
    Attached Thumbnails Attached Thumbnails Replacement Screws and Bolts-2-jpg   Replacement Screws and Bolts-1-jpg
    Replacement Screws and Bolts-3-jpg
    Dec 2008
    Sydney/Canberra
    Tap a spline bit into it.
    Get a replacement from VW.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mar 2015
    Quote Originally Posted by Umai Naa!! View Post
    Thanks for the reply, Umai. Can I go into any VW dealership and just pick up the part?
    Dec 2008
    Sydney/Canberra
    They'll have to order it in, but it won't be any more than a day or two.
    '01 Beetle 2.0
    Oct 2010
    Melbourne, VIC
    You could try vise grip pliers on the head to remove it.
    Also, you could try a wreckers for the screw or even a socket head (allen) bolt of the correct length and thread (and washer)
    Resident grumpy old fart
    Mar 2015
    How would I reference that specific bolt?
    You guys are great. Thanks heaps for the advise!
    Erskineville, NSW
    just grab it with vice grips - I doubt it's very tight.
    Replace it (and maybe the remainder on that component) with a allen head or a hex head from your local fastener shop.
