Results 1 to 5 of 5
Thread: Replaced front Rotors and Pads
    Jun 2021
    Wollongong NSW
    I have today replaced the front rotors and pads with Bendix Euro+
    and now I have noticed that the brake pad sensor is incorrect.
    The solution was to cut it and solder the new 1/2 one to the new old one
    the only problem now is that the brake pad warning light up on the dash
    No fault codes on the OBD2 scanner or on the mechanic scanner
    I need to know the resistance value thats needed to cancel this warning on the dash
    or if I can VagCom it or use the OBD2
    Its annoying as it comes up every time I start the car
    cheers
    Golf Mk6 R
    The easiest solution be to buy new wear sensors and fit those to the new pads. Wear sensors are pretty cheap.
    Are you saying that the wear sensors that came with your new pads are not the correct ones? Do they not fit into the pad, or is the wiring plug incorrect?
    Jun 2021
    Wollongong NSW
    male to male socket dont fit
    Ill see where I can get them from
    Thanks Lucas
    Golf Mk6 R
    Dec 2007
    Just short the two wires, your dash light will turn off.
    2008 Blue Graphite GTI DSG with Latte leather. SOLD 4/9/2024
    2023 T-ROC R - Sunroof, Black Pack, Beats Audio
    Jun 2021
    Wollongong NSW
    Exactly what was done.
    If anyone can help . I need to know the OEm part number from VW for the brake pads and brake wear sensor
    Can anyone confirm that the pads and brake wear sensor from VW
    is 8JO698151F
    cheers
    Golf Mk6 R
