Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Recommend an outdoor weather resistant car cover for Golf 118TSI Mark VI
    May 2012
    Sydney NSW
    jc29 - there are plenty of options for you re protection/storage/cover etc. for your car. If you are going to leave the car in one spot longer-term then that is another thing altogether. If it is only for short term cover . . . then you are better off giving it a wash more often rather than pulling on/off a cover all the time.
    Do agree with the others re putting a cover on your car. Better to wash the car to remove any dust that settles on it than to have scratches due to grit/dust/dirt between the cover and paint!
    Quote Originally Posted by jc29 View Post
    It's been a while since I've last been on. Will give Dave a call this week. Anyone know how long it usually takes?
    Had my new car given the Opti-Coat treatment by Dave at Reflect Effect (full cover, incl. outer face of alloys + got him to tint the windows while he was at it and put some clear protective film on the tailgate loading area). This took him about 2 working days as he needs to clean the car surfaces thoroughly before the Opti-Coat can be applied and the other work I had him do also added time.
    I had him Opti-Coat all the external 'glass' (including windscreen, wing mirrors, head/tail lights etc.) and he said that you need to let the coating cure at least a couple of days before using wipers. In the wet, at highway speed (90+ km/h) I find that I do not need to use wipers very much, if at all (even if the car is not washed) as rain/water beads and runs off by itself and I can see quite clearly through the windscreen even at night with on-coming traffic headlights . . .
    My advice: speak with Dave, he will tell you how long your car will take based on what you want him to do.
    Personally, I am very happy with the result and would do it again with no hesitation.
    If you want 'more' protection, then you can always put a protective sealant/wax etc. on the car on top of the Opti-Coat (which is essentially another but tougher clear coat on the paint) as per what Candyman said. Basically, comes down to personal preference/choice and how much time/money you are prepared to put into it.
    MY12.5 B7 Passat Wagon : : TDI Highline : : Icelandic Grey : : black leather interior
    sports pack | sat-nav | panoramic glass roof | adaptive cruise control | driver/lane assist | bi-xenons/LEDs | RVC plus | auto-park | auto tailgate | tow-bar | mud-flaps | sill-protection | wood trim - ||| - Lakin plate mounts | tinted | Opti-Coat | LED reverse lights | bright white driving lights + turn lights (LEDs were too 'dim')
    Mar 2008
    Sunshine Coast
    No wind, the product I use is a stand alone product
    Does not need OptiCoat under it
    User applied, easy to use, all surfaces
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
    Jun 2012
    Campbelltown NSW
    I want to get my GTI done..fairly new car <300Km's just haven't had the time to get paint protection on it, didn't opt for the paint protection option provided at the dealer.
    Car is barely driven, only driven in the rain once (fairly light showers), parked under cover.
    Should I get a Stage One (1) enhancement before Opti-Coat is applied?
    @wind: I'll send him an email since it's pretty late now.
    @Candyman: Appreciate it, but no need to try, looks like it works just fine.
    1st Owner: 2012 Golf GTI Carbon Grey Steel (Manual) - Bluetooth, MDI, 18" Detroits, RVC, Rear Sensors, Privacy Tint, Bi-Xenons, Dynaudio, GIAC, Dieselgeek SS, 034 Pendulum Billet Insert, 034 Engine+Trans Mount, CTS Downpipe
    Mar 2008
    Sunshine Coast
    The product I used is not OptiCoat
    The product I used is considerably cheaper and user applied
    May 2012
    Sydney NSW
    Candyman, I agree with you that you can get some great results without going the whole hog (like I did!) or blowing the bank in the process.
    The reason I went with Opti-Coat is the permanence of it . . . you still end up using 'stuff' on top BUT when that wears off (sooner or later) you still have the Opti-Coat.
    jc29, speak with Dave @ Reflect Effect. He will tell you what needs to be done to prep your car - he did tell me that if the car does not come straight from the dealer there is a little extra work involved.
    Re dealer paint protection - plenty of posts on this forum, and from my reading of them they are pretty uniform in feeling from most posters is that they basically take a big chunk of your money and give you an ordinary result , much better to go direct to the pros (or even DIY) and get a great result and still walk away with cash in your pocket.
    Mar 2008
    Sunshine Coast
    wind
    The sealant I am using has lasted 12 months on the wife's Fiesta and still protecting (is parked outside)
    I didn't go the whole hog nor break the bank. I applied it myself (anyone can do it) and it cost a fifth of OptiCoat and performs as well.
    Your choice though
    May 2012
    Sydney NSW
    Quote Originally Posted by Candyman View Post
    That's a great result Candyman . . . definitely want to look into it for my other car/s (only the Passat got the 'royal' treatment).
    Can you name the product you used (or even what the label on the bottle says)? With so many different products out there it can be hard to pick a good one.
    I am always happy to benefit from the experience of others (hence why I am here)
    . . . my definition of experience = "something you get just after you really need it!"
