Page 8 of 8 FirstFirst ... 678
Results 71 to 72 of 72
Thread: Rear sway bar for MK6 Golf GTI
  1. #71
    Apr 2012
    Got the sway-bar installed... reports are it's awesome but now I feel the front is alittle loose. What's a good combo 24mm or 26mm, FSB?
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
  2. #72
    Apr 2015
    Rear sway bar for MK6 Golf GTI-kca316-jpgRear sway bar for MK6 Golf GTI-bwf19xz-jpgRear sway bar for MK6 Golf GTI-kdt914-jpg
    On the MK6 Gti we added a Whiteline caster and anti lift kit (KCA316), rear adj swaybar (BWR20XZ)and a void filler for the front torque arm bush (KDT914). The swaybar and void filler were pretty easy to fit up on the hoist in the race car workshop. The anti lift + caster kit was a fair bit more difficult and requires some experience to fit.
    Overall a huge improvement, no more axle tramp (filling the void certainly helps), improved turn in from the increased caster, less mid corner roll plus improved corner exit from the swaybar (currently on the softest setting). We also ended up at 2 mm toe out per side (standard was 2 mm toe in) which helps as well. A lot of gain for not a lot of cost.
    Gary
