This is what one of the technical advisers mentioned to me from ECS tuning
Quote: If you went 24mm at the rear your are prone to drifting almost every corner as this will cause the rear to over steer, where as 22mm will create a more stable turning experience.
Now I'm confused...??
GOLF GTI MY11 ADIDAS Candy White, Sunroof
GOLF GTI 40th ED, White with Sunroof
Yeah the one thing I've noticed is most ppl go stiffer the front than back... and if you went 24mm rear than that's the opposite so go figure...22mm just seems a safer bet if you don't plan on going for both and leaving the front stock. However if you went both I'd probably go 24mm RSB with 26mm FSB.
Stiffer front is safer - cures body roll but exacerbates understeer. That's probably how the car is set up from factory in terms of balance.
