I got the SPM swaybar about a year ago from Dubaddiction. Its adjustable and from memory i believe its 22mm.
Plenty of other choices out there though - Superpro, Whiteline, H&R etc.
I wanted to bring this thread back.
Wondering what people have done in terms of RSB or FSB, 22mm or 24mm?
Looking to get one for my MK6?
GOLF GTI MY11 ADIDAS Candy White, Sunroof
GOLF GTI 40th ED, White with Sunroof
I had also read that 24mm was too stiff so thats why i wanted the 22mm. Dont forget the aftermarket swaybars are solid whereas the stock ones are hollow (aftermarket ones weight at least 2x more).
I fitted the swaybar along with new SPM lowered springs and Koni shocks - so the cars handling changed quite a bit with all that.
I've fitted several 24mm rear bars from Super Pro to Mk6 Golfs now and have only had good feedback. One point of difference between the super pro and the whiteline bars: the lateral limiters are built into the super pro bars (like OEM),whereas the whiteline bars use a crappy little bolt-on alloy bracket which can foul on the crossmember if fitted incorrectly.
I run a 24mm front and 26mm rear bar in my Tiguan (same chassis,heavier car) and it's not too stiff by any means.
Regards,
Justin.
Justin - Enthusiast's Warehouse. Need parts? Pm me.
Cars in the driveway: 2021 Passat B8 RLine 206TSI Wagon, Mk8 Golf 110TSI Wagon, Toyota AE86.
No issues adding just a 24mm rear bar to mk6 GTI.
Regards,
Justin.
I've got the Whiteline 24mm front and rear sways on my 118 TSI. They do require regular greasing about every second service. Run on the medium setting they're firm but not overly stiff. On the hardest setting it corners flat as a pancake but is a bit much for day to day driving. I'd go for something with better rubbers next time. The supposedly upgraded rubbers Whiteline sell are too expensive to bother with.
How does Super Pro compare anyone got these?
