Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 72
Thread: Rear sway bar for MK6 Golf GTI
  1. #21
    Erskineville, NSW
    Quote Originally Posted by bigfoot View Post
    This setup was suggested on Pedders’ website and on a Whiteline youtube vid:
    BWF20XZ Whiteline 24mm Adjustable Sway Bar (Front)
    BWR21XZ Whiteline 24mm Adjustable Sway Bar (Rear)
    KCA316 Whiteline ALK
    What is the best place near the Inner West for suspension – or should I just go to pedders?
    Unless you know the guys at Pedders I wouldn't go near them as the standard of workmanship & knowledge is too variable.
    try Heasemans although you will pay for the experience.
    Another good guy is Metro Service Centre at Marrickville
  2. #22
    Nov 2010
    Thanks Brad
    Is a wheel alignment required when changing sways and/or adding ALK?
    MY18 Golf 7.5R - Ecotune Stage 1
    Mazda RX2 - 13B Bridgeport GTX4202R
  3. #23
    Erskineville, NSW
    RARB = no
    FARB = yes because they have to drop the crossmember and the bolts fit in the holes like a pr!ck in a shirtsleeve so it never goes back together the same.
    ALK = yes
    So it would be wise to do the FARB & the WALK at the same time.
    I would strongly recommend that rather than the ALK you either do the Supaloy lower control arm kit or fit S3 alloy lower control arms & a non voided console bush.
    For no particular reason I'm really not sold on the ALK. I think the Supaloy kit has ALK incorporated.
  4. #24
    Nov 2010
    Thanks again - yep supaloy includes ALK. Almost triple the price and more labour involved though especially in a DSG car (need to drop the subframe to clear the 'box). But i'l lkeep it in mind...it looks like a nice bit of kit.
  5. #25
    Quote Originally Posted by MozzGTI View Post
    Hi all looking to pick up a rear sway bar for my GTI. What size does everyone recommend?? 22mm, 24mm?? The car has lowered springs if that is helpful.
    Is this good bang for buck handling upgrade??
    Thanks all
    I got the SPM swaybar recently from DubAddiction. Well priced ($280), fits well and does the job.
  6. #26
    Jan 2015
    Brisvegas
    What size Lucas?? Did you get wheel alignment too?
  7. #27
    Doesn't need aligning as nothing is undone to fit it.
  8. #28
    Nov 2010
    how many hours labour typically to fit whiteline ALK? (not including alighnment)
  9. #29
    Erskineville, NSW
    It's 3 bolts per console housing. You might also have to undo the front bolt to give you a bit of wiggle room.
    I'd think 1.5 - 1.8hrs including putting it on the hoist, etc
  10. #30
    Nov 2010
    Thanks mate. Booking it in for next week
