Page 3 of 3 FirstFirst 123
Results 21 to 21 of 21
Thread: Rear boot door is bad design?
  1. #21
    Feb 2009
    NSW
    Just did this simple mod.
    Unbolt the ball joint on the body and rotate it 180 deg. It's the black bracket held on by 2 torx bolts.
    You will have to unhook both struts to make it easier and use a broom handle to hold it up or do what I did and use your head!
    Once both the brackets are backwards (no need to swap side to side- just rotate it!), the hatch will be slightly lower. *
    Once this is done, close the hatch (will need more force to close, but I'd rather that than a hatch that doesn't know if it's open or closed!)
    Push and hold the middle boot release button and watch your 10mins of handy work!
    *You will need to get the other sturts if you want the hatch to clear your head (if you're tall or just duck a bit more!)
    Cancel that. The struts aren't strong enough to push the hatch up. Looks like I'm going to order the Skoda struts!
