Results 1 to 10 of 13
Thread: RDS on RCD510 doesn't work for certain radio station
    Hey guys,
    When I got my MK6 GTI I had FOX FM listed as a preset. Then out of nowhere it disappeared.
    I have done a factory reset on the unit and for whatever reason, Whenever I manually scan to 101.9 (FOX FM) it does not appear as FOX FM anymore. only as the radio frequency, and then after about 20seconds or so, the frequency disappars and I just get 3 lines (- - -)
    I DO have RDS enabled, as all the other radio stations appear as you would expect. Its really odd!
    Can anyone help with this one?
    I am getting the car looked at for a leaking brake light cluster on Wednesday, Should I ask them to look at the headunit too and request a replacement?
    It is such a minor thing I know, but its really annoying me, and for a 50K car this stuff should just not happen!
    MK6 GTI 3 Door - Candy White - DSG - Sunroof - 18" Detroit - ACC - PA - RC - MDI - BT - RNS510.
    Perth WA
    Sounds more like an issue with the actual radio station than the unit. RDS may be unavailable on that station for some reason.
    Good point.
    Can anyone with a MK6 Golf and a RCD510 confirm if FOX FM appears on as FOX FM and not as - - - or 101.9???
    Nov 2009
    It's the radio station. RDS info disappeared from my non VW car the other day too.
    Dec 2009
    nothing wrong with the head unit, as my sig suggest i drive one to.. liken Glennb said, it's more the radion station then the headunit...
    GTI Mk6 5 door/6 spd DSG/Candy White/Bi-Xenon/18" Detroit Wheels/Leather/Boot Trim/Dynaudio/MDI/Electric Seat/WHITELINE SWAY BAR 24" ADJUSTABLE
    Mar 2010
    Witness Protection
    On the topic of RDS, besides the name of the radio station, is there any more information available from this feature? Does the traffic info work?
    Apr 2010
    ringwood, vic
    my VW Jetta, used to display FOX FM, now it changes to 101.9 after a few seconds, still displays song name, seems to be on the radio station side and not the head unit. Also shows NO TP "top left of the screen" when tuned to FOX FM.
    Adelaide hills, SA
    Quote Originally Posted by simonn View Post
    Maybe you just pressed something on the radio and changed some settings. Fastest way to find out, could be to look at the radio manual.
    Jan 2008
    Quote Originally Posted by hooba View Post
    Do a forum search on "SUNA" and you'll get the answer to your last question.
    As for the first question there is a heap of info available like station name, programme type, text for ads and currently playing song, traffic announcements (not TMC) but a voice announcement which pauses the CD/Radio and continues afterwards and so on. Most of this is not used in Australia as we're too backwards.
    Apr 2010
    ringwood, vic
    MIX FM 101.1 do display the weather forecast
